Author Topic: Cooling system leak  (Read 4029 times)
Mike_T
  • Trimley Nr Felixstowe
Cooling system leak
« on: 17 June 2009, 19:15:10 »
Hi, I have a cooling system leak coming from a plastic cylindrical unit at the back of the engine on o/s of my V6 it is leaking from the body of this unit as though it has a hole in it. It is very difficult to see how many hoses are attatched to it. Please can you tell me what this unit is and why should it be leaking from its body.
Thanks Mike.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Cooling system leak
« Reply #1 on: 17 June 2009, 19:19:11 »
Sounds like the HBV (Heater Bypass Valve) mate, around £30-£35 from Vauxhall :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #2 on: 17 June 2009, 19:21:07 »
There should be three pipes coming off it if I remember correctly. You could do with getting it fixed as soon as you can as leaving it will only cause more problems, rusting and damaging your dispack (the old distributor) if you don't :y
Mike_T
« Reply #3 on: 17 June 2009, 19:27:20 »
Ok thank you very much for your help its much appreciated, I will get it done asap Thanks again :y
« Reply #4 on: 17 June 2009, 19:56:03 »
Not a difficult job to do your self.  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
be carefull of where the plastic vacuum pipes are T'd off from the brake servo non-return valve .... they're easily snapped off (and goo 'uns are not always easy to find in the scrap yard ::))
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #5 on: 17 June 2009, 20:05:18 »
Not if you remove the scuttle panel ;)
« Last Edit: 17 June 2009, 20:05:49 by Loo-knee »
« Reply #6 on: 17 June 2009, 20:11:27 »
I've only ever removed the scuttle panel, is it even possible without doing so? ::)  ;D  ;D   :y
« Last Edit: 17 June 2009, 20:23:36 by Andy_B »
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #7 on: 17 June 2009, 20:14:18 »
You can do it without removing the scuttle panel but is a bit of a squeeze..  :y
« Reply #8 on: 17 June 2009, 20:25:10 »
but the point being ... is that the T's get brittle & are easily broken due to living under a hot bonnet.  :y  :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #9 on: 17 June 2009, 20:29:40 »
If you remove them they wont get broken  ;D
« Reply #10 on: 17 June 2009, 21:04:25 »
Who testin who here?  :-? I do, as I once broke a T .......
but I thought we were advising Mike T ....  ::) ::) ::) :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #11 on: 17 June 2009, 21:08:55 »
Put your dummy back in Andy lad ;D
I would advise Mike T to remove the scuttle panel so there is easy access, this way you should not break any T pieces :y
Stokie Steve
  • Stoke on Trent
« Reply #12 on: 17 June 2009, 21:14:36 »
Calm down ladies ! ;D
Daz, think I saw your motor yesterday, parked on the grass on W****** Rd, looked very nice if it was yours !
Steve
« Reply #13 on: 17 June 2009, 21:23:46 »
You'd know if I ever spat my dummy out .......  ;D  ;D   ;D
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #14 on: 17 June 2009, 21:39:26 »
Steve
Yes mate that would be mine :y
