Author Topic: HELP!! I need to get the new type oil filter off  (Read 1871 times)
Elitenut
  • Redditch, Worcestershire
« on: 18 June 2009, 13:35:02 »
Could somebody please tell me how to remove the new type oil filter container?
 I need to remove the pipes to the oil cooler.
I have managed to remove the outer cover and filter.
What is the casing held on the block with?
What tools do need to get it off with?
Re: HELP!! I need to get the new type oil filter off
« Reply #1 on: 18 June 2009, 13:40:18 »
Inside the housing is a bolt assembly, its either a large hex or an allen key type(two different types)
Elitenut
« Reply #2 on: 18 June 2009, 13:53:18 »
Thanks Mark for your quick reply.
Have you got any idea of the sizes they might be?
I need to go and borrow the suitable tools from work.
« Reply #3 on: 18 June 2009, 14:28:44 »
Cant recall...if hex its sort of 27mm ish
Elitenut
« Reply #4 on: 18 June 2009, 21:41:54 »
Thanks for the replies, I've got it off. Found a 12mm allen key in my late fathers tool box.
