Author Topic: my car problems  (Read 1537 times)
Shane mvsex
  • maidenhead
    • 3.0 pfl mv6 caravan
my car problems
« on: 19 June 2009, 11:37:32 »
 after having the engine cut out on me, i went to change one of my lambda sensors only to find it was finger loose half out basically...
so i tightened it back up.. gave her a start sounds ok again....
i need to give it a run see if its any better..
but i did the paperclip test and its still flashing up 89 which is the sensors but now is also flashing 19 incorrect rpm signal......
any ideas?
should i give her a run n find out.....
migs and rc helicopters yeeeehaaaaaaa!
Www.omegaowners.com
Www.omegaownersnetwork.com
CBH
  • West Sussex
Re: my car problems
« Reply #1 on: 19 June 2009, 11:42:45 »
Code 19 is the crank sensor.
I had the same problem with one of my lamda sensors loose. It takes a few miles of driving before the ECU sorts itself after you fix the leak
cbh
Shane mvsex
  • maidenhead
Re: my car problems
« Reply #2 on: 19 June 2009, 11:44:55 »
ok thanks
so if i give it a nice run do you think it will clear up the problem??
ta :y
Www.omegaowners.com
CBH
  • West Sussex
Re: my car problems
« Reply #3 on: 19 June 2009, 11:49:05 »
My car ran much better after a quick blast of about 25miles.
The code 19 is normally only fixed by changing the sensor
cbh
Re: my car problems
« Reply #4 on: 19 June 2009, 12:29:42 »
The 19 is the likely reason it broke down. No amount of running/cleaning/playing will cure it, it needs replacing.
Shane mvsex
  • maidenhead
Re: my car problems
« Reply #5 on: 19 June 2009, 12:29:50 »
looks like the cars not going anywhere till i can change all 3 sensors grrr
not what i wanted to find out today...
cheers for the help  :y
Www.omegaowners.com
