Author Topic: Air Con Valves  (Read 1907 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Air Con Valves
« on: 19 June 2009, 19:28:02 »
I know you can get a new valve for the low pressure valve to the side of the plenum, looks similar to a tyre valve, but the high pressure valve behind the radiator looks like a ball bearing instead of a valve.
I have been up Vauxhall who can't tell me the part I need for the front one :-?
So does anyone have a part number or do I need to get the whole pipe from the condenser to the air con pump?
Cheers :y
« Last Edit: 19 June 2009, 19:30:30 by Loo-knee »
markey mark
  • SLady bitshorpe north lincs
Re: Air Con Valves
« Reply #1 on: 19 June 2009, 19:33:45 »
think its the whole pipe daz  :(
Re: Air Con Valves
« Reply #2 on: 19 June 2009, 19:45:45 »
Cheers :y
Told you once!!!  ::)  :P
52458177  :y  :y  :y
As & when/if I ever give my garage a tidy out, the old one might still be around ( it was only Christmas when I had my A/C sorted out) but that number will definitely unscrew from the pipe .....
unless of cousre different years have the valve as part & parcel of the pipe.  :-/  :-/  :-/
« Last Edit: 19 June 2009, 19:48:36 by Andy_B »
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Air Con Valves
« Reply #3 on: 19 June 2009, 20:04:10 »
But I was under the impression you see that the black cap stops the valves leaking :-?
Captain has sorted me with all the part numbers too Andy but thanks Andy  :y
Going to swap my Condensor too so will get the o rings too :y
Re: Air Con Valves
« Reply #4 on: 19 June 2009, 20:06:34 »
they can only help cos you have to remove the cap in the first place to fill via the valve.  ;)  ;)
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Air Con Valves
« Reply #5 on: 19 June 2009, 20:08:14 »
Ok fair point ;)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Air Con Valves
« Reply #6 on: 19 June 2009, 20:24:39 »
Must be dodgy aircon week as mine has stopped working too.
Time to pay the aircon man a visit methinks.
TuBy's new whipping boy.
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Air Con Valves
« Reply #7 on: 19 June 2009, 20:25:43 »
Suppose there will be a few more before long when the nice weather eventually gets here  ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Air Con Valves
« Reply #8 on: 19 June 2009, 20:31:57 »
Get Pete to buy you the kit and we can set up as aircon fitters before the rush. :y
Re: Air Con Valves
« Reply #9 on: 19 June 2009, 20:54:08 »
Well, while your A/C is gasless, just to prove a point for the Daz, you could unscrew the HP fill valve.  ;D  ;D  ;D
Dazzler
  • Haverhill, Suffolk
Re: Air Con Valves
« Reply #10 on: 19 June 2009, 21:55:37 »
Its a sort of 15mm fitting.......I say sort of cos its a tight fit, i believe its a 'special' socket required ::)
Re: Air Con Valves
« Reply #11 on: 19 June 2009, 21:58:02 »
Pretty sure I just used an ordinary 15mm socket, possibly 6 sided rather than a 12 point.
unlucky mark mv6
  • tipton,west mids
Re: Air Con Valves
« Reply #12 on: 20 June 2009, 16:32:48 »
Cheers :y
Typical dealer mate,seem to be getting worse lately. :o
