Author Topic: Clutch & Dual Mass flywheel  (Read 1993 times)
924boy
  • Rhuddlan, N. Wales
« on: 26 June 2009, 17:20:24 »
my '97 2.5 v6 needs a new clutch after getting extremely hot whilst towing up steep hills and getting lots of slipping. It doesn't slip now but is difficult to get into gear. Whats the liklihood the dmf will need replacing and the slave cylinder? all the parts seem very expensive wherever I've looked...  :-/
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: Clutch & Dual Mass flywheel
« Reply #1 on: 26 June 2009, 17:22:47 »
Have you adjusted the clutch ?
He who brakes Looses
To old to die young
924boy
« Reply #2 on: 26 June 2009, 17:25:24 »
what adjustments can you do to it? and after getting hot and smelly will adjusting it do anything to prolong its life?
Ghost
    • 2.6 V6 CDX Estate
« Reply #3 on: 26 June 2009, 17:42:15 »
on the gearbox is an arm where the cabel goes in, normaly you can adjust them by tightening or losening the nut on the end. not to sure with the mig though my car is missing this pedal.
but the other guys would put me right.
To old to die young
« Reply #4 on: 26 June 2009, 17:58:04 »
Lol, no adjustment possible on the clutch....as its hydraulic!
Anyway, depends hwo hot its got.
On Omegas, the slave cylinders dont go and the DMF's are very reliable, the only question will be, has the clutch got so hot that its damaged the DMF.
924boy
« Reply #5 on: 26 June 2009, 17:58:57 »
its hydraulic unfortunately so no cable to adjust...   :(
924boy
« Reply #6 on: 26 June 2009, 18:00:39 »
lots of slipping but once cooled down seemed to be fine. its just tight when putting it into gear now but drives fine.
