Author Topic: Outside Air Temp  (Read 3046 times)
Re: Outside Air Temp
« Reply #15 on: 19 June 2009, 16:50:51 »
Cheers lads!! i have got a climate control problem as well, anything but low comes out redders!!. i'll have a look at the connector tonight.
that'll be the sensor, so related :)
Snake Pliskin
« Reply #16 on: 27 June 2009, 17:39:02 »
i have disconnetcted multi plug and found one of the 4 pins has corroded and ended up stuck in the female half of the plug. Does anyone know if i can just connect the cables directly to each other without having the plug in the line? I can't see that it does anything other than serve as a connector... :-/
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #17 on: 27 June 2009, 17:55:17 »
Could do that, or speak to someone on here who's breaking one, and put a new plug in - but then I like things to look factory...
