Author Topic: Outside Air Temp  (Read 3065 times)
Snake Pliskin
Outside Air Temp
« on: 06 June 2009, 19:04:12 »
Just bought a 2000 2.5 v6 cdx. On way home noticed outside air temp showing -40. found this slightly suspicious as there were people wondering around in tee shirts. Checked it again today and now get an F on the left and just the degrees C on the right. Any ideas? ;)
Re: Outside Air Temp
« Reply #1 on: 06 June 2009, 19:07:01 »
most likely knackered sensor. Only a few quid from dealer.  It lives behind passenger side bumper (prefacelift) or behind middle of bumper (facelift)
Snake Pliskin
« Reply #2 on: 06 June 2009, 19:19:56 »
Thanks for that, i'll get one ordered and give it a go!!
Stokie Steve
  • Stoke on Trent
« Reply #3 on: 06 June 2009, 19:59:46 »
Ours has failed the other way, displays about +32C  8-) when its freezin' !
Does the bumper have to come off? Not that bothered about the temperature, but if it's easy to do will get one.
Steve
« Reply #4 on: 06 June 2009, 20:06:06 »
Steve
No, (for prefacelift) it's a push fit into a hole about 1/2 " dia on on the passenger side of the car from inside the bumper. If you look on the outside there's a small cut out too.
Snake Pliskin
« Reply #5 on: 19 June 2009, 13:23:52 »
mine is Omega B (i take it that is the facelift??). can't see sensor in middle of bumper...any help?? :-/
« Reply #6 on: 19 June 2009, 13:26:53 »
Check the passenger side. Guessing your`s is a mini-facelift ;)
« Reply #7 on: 19 June 2009, 13:30:49 »
Omega B (94-03) covers prefacelift and facelift. if its pre 2000, it'll be on passenger side, if it is 2000 or later, its in middle
Snake Pliskin
« Reply #8 on: 19 June 2009, 13:41:23 »
It's april 2000, so i'm going for another shuffty in the middle of the bumper again. i have got a new one, but just having a few probs locatin something that resembles it!!
Snake Pliskin
« Reply #9 on: 19 June 2009, 13:49:35 »
right, i've found sensor and changed it. Strill getting an 'F' on left hand side of computer display. Is this because the car is stationary or is there still a problem?????? :-[
« Reply #10 on: 19 June 2009, 14:06:59 »
Still a problem :(
Snake Pliskin
« Reply #11 on: 19 June 2009, 14:16:15 »
Oh deep joy. I guess it's time to start checking plugs and wiring...i can't tell you how excited i am!! Thanks for help anyway
    • 530D M Sport, 330i Coupe
« Reply #12 on: 19 June 2009, 14:17:18 »
Check the wiring!
It's worth getting it working because it does more than just display the temp on the display, I believe the Climate Control uses it's input as well.
markey mark
  • SLady bitshorpe north lincs
« Reply #13 on: 19 June 2009, 14:43:25 »
on the passenger side there is a multi plug there will be a broken or correded wire !  :y
Snake Pliskin
« Reply #14 on: 19 June 2009, 16:43:42 »
Cheers lads!! i have got a climate control problem as well, anything but low comes out redders!!. i'll have a look at the connector tonight.
