Author Topic: Big water leak back of engine  (Read 1093 times)
Martin_1962
« on: 27 June 2009, 18:47:18 »
Lost 2 litres in 1/2 hour of driving - air con well on (18c), last couple of days used very little water but less air con (21c).
My coolant bridge washers are knackered.
Could it be anything else?
Re: Big water leak back of engine
« Reply #1 on: 27 June 2009, 19:34:09 »
Whole shit load of things, you need to investigate!
Martin_1962
« Reply #2 on: 27 June 2009, 19:50:13 »
Was wondering if it could be HBV?
Even though it seemed fine
« Reply #3 on: 27 June 2009, 19:56:59 »
normally most likely, but seeing as you've done some work around there, you need to investigate
Martin_1962
« Reply #4 on: 27 June 2009, 20:06:40 »
I have 2 bolts, 4 washers on order, some new coolant hose to replace the dodgy one, will see if I can get hold of a JV6CDX as well.
Just umming and ahhing about an HBV.
Could even be the big pipe sealer has come loose
« Reply #5 on: 28 June 2009, 08:58:19 »
It could be from the transfer pipe which runs from the radiator hose on the left, to the rear of the engine.
MutantCav
  • Gainsborough
« Reply #6 on: 28 June 2009, 09:09:37 »
Really not having a good time of it engine wise atm are you Martin...sorry to hear that mate
Martin_1962
« Reply #7 on: 28 June 2009, 11:25:25 »
That wil be getting fresh grey gunge once 135 gasket has been done.
Martin_1962
« Reply #8 on: 28 June 2009, 11:25:48 »
Underside of HBV is damp - that says something
