Author Topic: car unstable at speed / plastic undertray missing.  (Read 1530 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 28 June 2009, 12:56:26 »
did a fair few mile last week and noticed that the car seems to go quite nose light at speed ( 80 upwards  ;) ;) )
have checked all tyres ........ rubber bushes ........ suspension ect  and all seems good  :y
i was carrying alot of weight in the back at the time.
is the missing undertray going to make much differance to the this ?
Martin_1962
Re: car unstable at speed / plastic undertray missing.
« Reply #1 on: 28 June 2009, 17:19:27 »
Check rear springs
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 28 June 2009, 17:28:48 »
checked mate ......... both look ok ( at the top and bottom )  :y
it was sitting pretty low at the back ( no self leveling )
just been for a blat up m62 ( don't ask how fast  ;) ;) ) with the car empty.
pretty much as before ........... started to go light above 80 ish  ;)
its the last time i buy a 500 quid car ........... spent over 700 quid on the heap of sh*t since then  >:( >:(
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #3 on: 28 June 2009, 18:23:05 »
Welcome to the world of Omegas.
I did the same as you, £500 purchase, over £1000 spent to get everything working right.
Great rewards eventually but yes..a pain in the ass meanwhile.
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #4 on: 28 June 2009, 18:26:52 »
lol...spent £425 for my first omega and was spot on ;)
had to do drop links and changed the timing belt anyway and that was it!
V8!!!!
Martin_1962
« Reply #5 on: 28 June 2009, 18:46:32 »
Back end down will cause this instability - also take it to WIM for a full geometry check
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #6 on: 28 June 2009, 18:58:53 »
The police would have carried a hell of a weight in the Omega when used as a Plod Car, they would have done silly speeds at times so I can't see weight in the back creating the car to go light at the front :-?
Are your wishbones ok? when going or shafted they steering does dance abit.
Not having a Plastic undertray will perhaps make your car run slightly warmer as the air is escaping and not channeled around the engine then up the gearbox tunnel.
« Last Edit: 28 June 2009, 19:00:35 by Loo-knee »
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #7 on: 28 June 2009, 19:43:30 »
If I remember my Aerodynamics lectures correctly... an engine bay is a right sod of a thing to have in a car. Air blasts downward from the engine bay at all sorts of practicallly-unpredictable angles/speeds. The undertray will help smooth this plenty. They are fitted to help reduce front end lift.
Great, problem solved, I hear you cry! What I dont understand is why the some models get one, others don't. As an educated guess, I'd say the undertray doesnt really make much of a difference. BUT Vauxhall fitted one, didn't they? They didnt fit it for the hell of it.
« Last Edit: 28 June 2009, 19:44:36 by DiamondBlackGeezer »
