Author Topic: warm start problem  (Read 2350 times)
bellers
warm start problem
« on: 27 June 2009, 20:34:50 »
mates 2.5td bmw engine has developed a warm starting problem.
starts dead on when cold. will start after a bit of driving if it hasnt warmed up that much. but once it heats up and sits bout 90ish on the gauge it will hardly start at all. i done the paper clip test and theres no codes showing up. it does fell a bit sluggish when driving to
Re: warm start problem
« Reply #1 on: 27 June 2009, 20:51:57 »
Common issue with that bosch pump.
I think there are aftermarket mods to overcome it, also apparently chipping cures it
richy08
  • sheffield
« Reply #2 on: 27 June 2009, 20:54:46 »
do the diesel magic trick clean the in tank pump and hope for the best mine done the lot but nothing worked for me but i was told that the way  to go mate  :y
bellers
« Reply #3 on: 27 June 2009, 21:15:56 »
cant seen being todo with cleaning as its only when its warm.
theboy you got any further info on the common fault and ways to fix it?
thanks
richy08
  • sheffield
« Reply #4 on: 27 June 2009, 21:33:17 »
its an idea that i was told from the guys here id try it they are far wrong i only saying wot these guys told me pal  :y :y
richy08
  • sheffield
« Reply #5 on: 27 June 2009, 21:39:28 »
oh and wot nearly cured mine i got it chipped mate a lot more power a lot less hassel   ;D
bellers
« Reply #6 on: 28 June 2009, 00:02:59 »
definatly an excuse to get it chipped then lol had it out there the night again and i took it down the road for a good thrash and got it up to heat. when i started it, it just about started and sat with a low idle and wouldnt let me rev it the after a few seconds the idle returned to normal i could rev away
bellers
« Reply #7 on: 29 June 2009, 00:08:37 »
anyone know why it would sit with a low idle when started and not rev for a few seconds?
he says sometimes it would just about start and do that and sometimes it wouldnt hardly start at all
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #8 on: 29 June 2009, 15:44:19 »
Mine has hot start problem also, worse when there is under 20 litres of fuel, (2.5 Tractor) it is chipped and I run Millers power 4 sport in the diesel also..  New battery 2 years ago, new starter last year, I poured cold water over the FIP, still no improvement...   any ideas??
