Author Topic: Engine to gearbox assembly  (Read 2780 times)
Salty
  • Fleetwood
« on: 24 June 2009, 15:34:19 »
I am hoping somebody can help here, I got my omega back after the garage I bought it from after they fitted a replacement engine after the cambelt failed on my way home from picking the car up. I've had the car back for a couple of weeks and it is running ok but when I had it up on the ramps I noticed that there appears to be a cover plate missing off the front of the gearbox bell housing (I can see the front of the flywheel) I phoned the garage up and they said it didn't have a cover plate on to start with. I was hoping someone could tell me the correct description for this cover  as I intend to get one and fit it(The car is 2 litre facelift with an auto box). Any help would be appreciated.
« Last Edit: 24 June 2009, 15:34:53 by Salty »
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: Engine to gearbox assembly
« Reply #1 on: 24 June 2009, 16:16:34 »
I would call it Bell housing flywheel cover plate.
No doubt Im wrong and someone will tell us the correct name. :-/
He who brakes Looses
To old to die young
Salty
  • Fleetwood
« Reply #2 on: 24 June 2009, 17:33:02 »
That's what I would have thought as well, but have also heard it described as a flywheel stone guard as well :-/
unlucky alf
  • worksop, notts
« Reply #3 on: 24 June 2009, 19:08:08 »
is it the tin plate you are on about,? if they say it was never there that means either the engine or the box has been out before as its sandwiched between b/housing & block so cant fall off. :o
Salty
  • Fleetwood
« Reply #4 on: 24 June 2009, 19:39:15 »
I think it may be that bit >:(
Salty
  • Fleetwood
« Reply #5 on: 25 June 2009, 08:10:59 »
Does anybody have any photos or links to photos of the area where the bell housing connects to engine(underside) so I can compare what I should have with what I've got?
Salty
  • Fleetwood
« Reply #6 on: 30 June 2009, 11:59:48 »
Thought I'd have another go, does anybody have any pics or diagrams of what I should have or even better have the part I'm missing.  With not having seen what was there originally I'm  a bit stuck so any help would be greatly appreciated.
andyc
  • Norfolk
« Reply #7 on: 30 June 2009, 12:58:43 »
Hi mate
No picture but i have a screen dump from EPC if that helps
Thetford. Norfolk
Salty
  • Fleetwood
« Reply #8 on: 30 June 2009, 13:14:17 »
Thanks that's excellent :y, just what I was looking for. Do you know what the part is called?
andyc
  • Norfolk
« Reply #9 on: 30 June 2009, 13:19:22 »
Plate, Lower clutch Housing but your going to need a second hand one as the are no longer available from GME
Andy
Thetford. Norfolk
Salty
  • Fleetwood
« Reply #10 on: 30 June 2009, 14:53:19 »
Thanks  :y now that I know how to describe it properly I'll try a few breakers. :)
