Author Topic: Air Con Leak under scuttle  (Read 1192 times)
johndm1957
  • Bedford
« on: 30 June 2009, 16:53:47 »
Had my A/C gassed up a week or so ago.....hot again already.
UV dye suggests a leak at the rear of the engine bay under the scuttle. Looks like it might be a loose connection, but how do you get to it?
Along with a big MOT failure this week (rear shox + exhaust), I'm getting a bit fed up with the car now!!
serek
  • huntingdon
    • 3.2 mv6
Re: Air Con Leak under scuttle
« Reply #1 on: 30 June 2009, 17:24:29 »
have same on mine on very hot days, leak under car back of engine is only water of AC pipes, dont thing this a problem.
« Last Edit: 30 June 2009, 17:25:45 by serek »
johndm1957
  • Bedford
« Reply #2 on: 30 June 2009, 17:48:43 »
I think you mis-understand......
Not a water leak, leak of air con gas/fluid which is only visible under UV light at rear of engine bay
« Last Edit: 30 June 2009, 17:49:28 by johndm1957 »
johndm1957
  • Bedford
Re: Air Con Leak NOT under scuttle
« Reply #3 on: 01 July 2009, 18:00:26 »
I was given false info by the apprentice....now the main man has taken a peek, says it looks to be a leaky joint, poss o ring, down right hand side under battery area.
Approx 1 hour to strip & repair.....
Does this make more sense?
