Author Topic: Cheapo Tech 2 works advice now needed!!!!  (Read 1216 times)
ScottieMV6
  • Swinton, Manchester
« on: 02 July 2009, 14:17:02 »
I got my cheapo tech 2 working today and cleared the fault codes off the car.
One of them came straight back so I assume this means that the fault is still there. It is SAI related so I want to just disconnect it. I disconnected the pump under the passenger wing but the fault code is stil showing.
Can someone please tell me exactly what I need to disconnect to stop the fault code showing?  :y
« Last Edit: 02 July 2009, 14:23:25 by scottie7275 »
I'd rather be scared to death than bored to death!!
Re: Cheapo Tech 2 works advice now needed!!!!
« Reply #1 on: 02 July 2009, 16:58:30 »
The only part of the SAI that the ECU can 'see' is the solenoid valve. Check that.
ScottieMV6
« Reply #2 on: 02 July 2009, 19:42:35 »
Sorry to be a dunce but what can I check on it? I have already had the wiring off it and checked for continuity. Not sure what else I can check.
A lot of people have said just disconnect everything as it is not required, but will this get rid of the fault code?
