Author Topic: More codes  (Read 1185 times)
valliant72
  • London
More codes
« on: 02 July 2009, 21:03:23 »
Hi, changed my crank sensor for an original VX one, did the paper clip test and now getting 57 idle control valve voltage low and 73 Maf sensor voltage low. Could i have a bad earth somewhere or an air leak, although i have checked for vacuum and airleaks and found none that i can tell.
MutantCav
  • Gainsborough
Re: More codes
« Reply #1 on: 02 July 2009, 21:49:36 »
Check you havent knocked the IACV electrical socket and that the pipes are also in firmly
Re: More codes
« Reply #2 on: 03 July 2009, 08:19:35 »
Does it run OK? Could be historic codes from someone switching ign on before noticing they hadn't plugged in MAF or ICV?
valliant72
  • London
Re: More codes
« Reply #3 on: 03 July 2009, 12:18:03 »
It seems to run ok, idles ok now. Seems a lil underpowered, hesitates when accelerating.
