Author Topic: Dirty headlight  (Read 2289 times)
bazzer
Dirty headlight
« on: 05 July 2009, 17:22:08 »
My nearside headlight glass/plastic/perspex whatever it is, is becoming discoloured. Does anybody know of a product that will polish back to a clear finish. Any other suggestions (other than replacing!)? 8-)
nick v6
  • walsall / west midlands
Re: Dirty headlight
« Reply #1 on: 05 July 2009, 17:22:58 »
dishwasher
 :y :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Dirty headlight
« Reply #2 on: 05 July 2009, 17:31:51 »
brasso or any metal polish does the trick  :y
spikerz
  • Perth,Scotland
Re: Dirty headlight
« Reply #3 on: 05 July 2009, 17:39:10 »
I used T-cut.
Omegadoha, Desert Member
  • Doha, Qatar
Re: Dirty headlight
« Reply #4 on: 05 July 2009, 17:42:46 »
Brasso, t-cut, polishing compound, alloy wheel cleaner and finish off with plastic polish.
Re: Dirty headlight
« Reply #5 on: 05 July 2009, 18:45:48 »
As Nick said dishwasher works bext, T-cut will do the trick though  :y
bazzer
Re: Dirty headlight
« Reply #6 on: 05 July 2009, 19:12:48 »
Great, thanks everyone. Up the 'ammers!
Just a thought. How the hell do you put it in the dishwasher? Don't think wife would like car in there ;D
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Dirty headlight
« Reply #7 on: 05 July 2009, 19:19:10 »
If you did decide to put it in the dishwasher (I wouldnt) you would have to take the clear plastic off of the rest of the assembly .
Your best bet is as said the t cut option and loads of elbow grease . If you do a search on here others have used very very fine sandpaper  :y
amba
  • Medway towns
    • German V6
Re: Dirty headlight
« Reply #8 on: 05 July 2009, 20:01:28 »
As mine where such a mess I decided to replace them .Be carefull if you go that route as original lenses are a straight swap but if you buy Depso aftermarket units they don,t have the cut out locating lugs and are a bit of a pain to relocate .
Mind now look like new and transform front of car..looks like it just left the showroom on day 1.
Bent valve
Re: Dirty headlight
« Reply #9 on: 05 July 2009, 21:02:13 »
I didnt know you could buy new lenses. where did you get them?
Miggy24
  • Exeter,Devon
Re: Dirty headlight
« Reply #10 on: 06 July 2009, 08:40:43 »
i put mine in the dishwasher it was me that told nick about it then when its done in the dishwasher t-cut it quickly and they will come up like brand new  :y
amba
  • Medway towns
    • German V6
Re: Dirty headlight
« Reply #11 on: 06 July 2009, 09:25:13 »
New lenses are not available as a part,but if you source a set of new headlights for correcty model at a good price then it is a fairly simple job to swop just the lense covers onto a set of Xenon,s to transform them to new.
As said you need to be carefull with the aftermarket Depso make as they don,t have all the plastic lugs and are secured only by metal spring clips,which then require a bit of modification to get to seal,but a lot cheaper than new Xenons,if you could still now get them.
