Author Topic: steering on estate 2.2 sport  (Read 1201 times)
sport
  • Stoke on Trent
« on: 05 May 2009, 23:28:29 »
Hi my steering is following the groves in the road its my first omega 2.2 sport and is the suspension different to the other omegas thanks
Re: steering on estate 2.2 sport
« Reply #1 on: 06 May 2009, 07:56:07 »
yes the suspension will be slightly lower and stiffer. following the lines in the road or 'tramlining' can be caused by badly worn tyres
« Reply #2 on: 06 May 2009, 08:37:41 »
start with tires, ware and pressures. Check track rod ends and stearing idler for play, but ultimately will probably be shot wishbone bushes most likely imho.
Also check rear donut bushes behind triangular plate below/under rear doors, little buggers they are...
sport
  • Stoke on Trent
« Reply #3 on: 06 May 2009, 17:39:27 »
Hi thank you
New tyres all round new track rods try wishbone next also
having trouble getting 1 st & reverse sometimes put it in 2 nd to get 1st ok when engine not running
sport
  • Stoke on Trent
« Reply #4 on: 06 July 2009, 23:01:59 »
sorted my wondering tramlining sterering after cheking replacing bushes and tyers to no avail i had 235,45.17 continentels tyers replaced with 225,55,16 wheels continentals diferent car handles alot better
