Author Topic: Re: centre locking pin  (Read 795 times)
amba
  • Medway towns
    • German V6
« on: 08 July 2009, 09:21:45 »
2 x bolts clearly visible with bonnet open on front panel.
1 x hidden bolt..requires curved headlight trim removed,screw behind corner of front grille,then if fitted .disconnect headlight washer water pipe if fitted,and remove small grille by front fog light.
You will then be able to see the "hidden" screw which can be removed with an long extension and socket.
The maintenaince section gives very concise intructions.
