Author Topic: Brake Upgrade  (Read 4918 times)
FYS
Brake Upgrade
« on: 22 June 2009, 12:41:36 »
Hi,
Anyone know of any decent brake upgrades for the front of the Omega?
Do Vauxhall Monaro calipers/discs fit, or Pontiac GTO is the same car in the States, I think?
Cheers,
Martin.
Re: Brake Upgrade
« Reply #1 on: 22 June 2009, 12:42:57 »
Is this for track?  If so, I suspect you'll get away with existing calipers etc, just need track discs and pads (obviously this isn't ideal for roads then)
Re: Brake Upgrade
« Reply #2 on: 22 June 2009, 12:55:52 »
depends how much performance your looking for. in my experience trade club pads are poor and give a wooden feel( Although others seem quite happy with them ) so i have fitted oe pads (jurid made it seems) and am now very happy with them. bloody should de at the price vx charge ::)
Re: Brake Upgrade
« Reply #3 on: 22 June 2009, 13:13:15 »
Probably still would want something better for track use....
FYS
Re: Brake Upgrade
« Reply #4 on: 22 June 2009, 22:10:25 »
Yep, thanks, we've used the car on track for about 3 years now and whilst the brakes are ok'ish, they are not really the best....
Even with Police spec pads (which Vauxhall supply to the Police for the Omega jobcars, and perform better at higher temps), and also running DOT5 brake fluid and braided lines, you end up with a long peddle after a couple of laps.....  so, not ideal.
Hence the questions about the standard Monaro or GTO calipers fitting the Omega.
On my road car (04 plate ex-Police Omega) I have groved discs, standard Vauxhall pads and DOT5 fluid and they protest strongly after a few miles of hard use....
Anyone upgraded apart from disc/pads?
Cheers,
Martin.
i260
  • Newport, South Wales
Re: Brake Upgrade
« Reply #5 on: 22 June 2009, 22:41:46 »
There was a new full set of Monaro brakes (calipers the lot!) on ebay a few weeks back, only about £300 as they were taken off the the 'factory' upgrade after build.- can't see why they wouldn't fit. Can somebody confirm or deny??
...or I suppose Lotus Carlton (Group C) set up could be interesting if you could get hold of them.
« Last Edit: 22 June 2009, 22:43:24 by i260 »
Saab 9-5 Aero 260ps
Diamond Black Geezer
    • & a silly coupe coming...
Re: Brake Upgrade
« Reply #6 on: 22 June 2009, 23:02:22 »
Monaros have a different PCD, not sure how that would affect the discs. Perhaps they'd just slip straight on, no probs, but actually theres 4mm of difference, or something stupid like that!?
Almost definite that LC front discs will go straight on, though.  :)
i260
Re: Brake Upgrade
« Reply #7 on: 23 June 2009, 00:08:09 »
Boo Hiss - just have to get some Monaro / HSV wheels then! Postage from Oz is only £450 a set!!!!  ;D
Hoo-ray for the LC  8-)
Saab 9-5 Aero 260ps
FYS
Re: Brake Upgrade
« Reply #8 on: 23 June 2009, 09:46:25 »
Hi, thanks again.
Not too worried about the discs, could continue to use the Omega discs, really want to know if the Monaro/GTO calipers will fit the hubs? Therefore, end up with a better spec caliper that hold a larger friction area - i.e. bigger pad.
Anyone?
Cheers,
Martin.
NaughtyNigel
  • Sedgefield, Co Durham
  • Naughty Nigel
Re: Brake Upgrade
« Reply #9 on: 23 June 2009, 10:51:22 »
I have heard good reports about EBC discs and pads, and they fit straight on.
I would imagine that the calipers are fairly standard throughout the range, but the mounting brackets will differ.
Does the MV6 use the same wheels and brakes as the Elite? I understand the front brakes on the Elite are bigger than the CD/CDX et al.
It might even be worth looking at Vauxhall van brake parts. Big GM doesn't make different parts unless it really has to.  ;)
NN
Why drive fast when you can drive fast in style? :)
V6Rich
Re: Brake Upgrade
« Reply #10 on: 23 June 2009, 13:14:08 »
I don't know whether or not Monaro components will fit an Omega, but I thought I'd make you aware that many Monaro owners are less than impressed with the standard Monaro CV8 brakes anyway, and that VXR and AP upgrades are popular.
Check the Monkfish Performance website if you want an idea of prices for the components.
I have standard discs and calipers on my Monaro CV8 with Performance Friction pads (factory pads are not good) which is fine for my needs, though I don't take liberties with them and suspect my Omega would probably perform a better emergency stop.
In summary, if you are going to drive your Omega hard, standard CV8 Monaro brakes are probably not the way to go.
HTH
deviator
  • Chesterfield
Re: Brake Upgrade
« Reply #11 on: 25 June 2009, 13:49:10 »
Do the Omega wishbones have the irmy brake coolers on? If not could you rob some, or design some for the omega?
For those not seen them, they are a plastic rectangular tube with an angled down bit at the front to pick the air up and an angled up bit at the back to blow the air on the vents in the discs. In veccy land these just clip to the bottom of the wishbone.
Just an idea, although I can see why you would want better calipers.
FYS
Re: Brake Upgrade
« Reply #12 on: 09 July 2009, 09:08:17 »
No one upgraded calipers then - will I be breaking new ground then?
Thanks V^Rich, my pal has a Monaro and his brakes are fine, even when pushed hard, way better than the Omega anyway. I am aware of Monkfish (due to my mate having a Monaro) and I am also aware that an AP brake upgrade from then is probably worth more than the car!
The standard Monaro calipers are 'better' than the Omega, it is a bigger caliper/pad and therefore larger friction area and better braking....
Oh well, i'll keep trying....
Cheers, Martin.
Mart.
« Last Edit: 09 July 2009, 09:15:42 by tallchap »
Re: Brake Upgrade
« Reply #13 on: 09 July 2009, 09:10:30 »
one of the US members has done an upgrade on his Catera.  I think he used 6 Pot Corvette calipers.
Re: Brake Upgrade
« Reply #14 on: 09 July 2009, 09:12:32 »
You can see the calipers in his pics here.
http://www.omegaowners.com/forum/YaBB.pl?num=1244061134/0#0
