Author Topic: Cam belt fitting in Stoke on Trent  (Read 1709 times)
DZB
  • Stoke on Trent
« on: 06 July 2009, 08:22:44 »
Help!
I took my 2.5 V6 to a local garage on friday to have a cam belt kit and water pump fitted.  Now the once smooth tickover is rough and noisy (did not notice it when I picked the car up as it was raining).  I do not trust the garage to have another go at it as I am sure they have not fitted the cam belt correctly.  Does anyone know where in Stoke on Trent I can get the job done correctly?
David B
Re: Cam belt fitting in Stoke on Trent
« Reply #1 on: 06 July 2009, 08:30:34 »
Try contacting Darth Loo-knee on here  :y
DZB
  • Stoke on Trent
« Reply #2 on: 06 July 2009, 09:13:01 »
Thanks - but how do I contact him? (I do not know how to use your PM system)
David B
jonathanh
  • coventry
« Reply #3 on: 06 July 2009, 09:21:48 »
Hang on a minute and I'll pm for you and point him to your post.  Edit: done
In the meantimg DO NOT start your car - it really does sound like they've bodged something
« Last Edit: 06 July 2009, 10:15:17 by jonathanh »
« Reply #4 on: 06 July 2009, 12:58:39 »
Daz has just left mine and should be on in a mo :y
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #5 on: 06 July 2009, 19:02:26 »
I would document what Loo Nee finds if and when he strips it down preferably with photo's then if anything untoward is found you will have evidence to demand a refund off the garage. Also ask the garage if they used a cambelt locking kit on it and if the answer is yes ask to see it . You would be surprised how many garages think that a Omega belt can be fitted without one. The truth is they can't properly.
The engine will run rough if it is a couple of teeth out any more and it goes into self destruct mode with valves hitting pistons
« Last Edit: 06 July 2009, 19:07:03 by Tony_H »
Martin_1962
« Reply #6 on: 06 July 2009, 20:51:36 »
A mechanic near work says that a locking kit isn't necessary for doing the V6s. :(
He can now AFAIC stick to doing MOTs
« Last Edit: 06 July 2009, 20:51:49 by Martin_1962 »
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #7 on: 06 July 2009, 20:56:35 »
I watched my mechanic strip mine down when doing the cambelt, he was horrified to see tippex marks on both banks of cams, not surprisingly they were way way out, 5 degrees as I recall :o
Martin_1962
« Reply #8 on: 06 July 2009, 23:05:19 »
As I swapped the pulleys on 246 I repainted the marks!
Mine is very accurately timed
ejr1039
  • Newport Pagnell
« Reply #9 on: 10 July 2009, 07:37:02 »
Help!
Check that they have reconnected the idle air valve plug, I have had this happen twice, just plug it in and it was OK.
