Author Topic: Elite estate 2.5 1998 'automatic gearbox, check'?  (Read 1253 times)
bootyboy2006
« on: 12 July 2009, 15:05:44 »
Hi, our Omega Elite automatic estate 2498cc 1998, keeps breaking down. It cuts out and we get the message 'Automatic Gearbox, check' on the dashboard. Then it won't start again for about 10 mins. Can anyone offer any advice. Have had to have it towed to garage but mechanic didn't seem to have any ideas? Am hoping it is something simple :(
Re: Elite estate 2.5 1998 'automatic gearbox, check'?
« Reply #1 on: 12 July 2009, 15:24:37 »
Your car needs plugging in to a fault code reader to see what it's complaining about. Gearbox fault could be a number of things, some not directly related to the gearbox itself.  :y
hubbardybubbardy
  • West Midlands
« Reply #2 on: 12 July 2009, 15:29:13 »
Hell there
In order to check the fault try the paper clip test it works a treat and I did it Friday and identified my fault straight away
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
use this link or look for it in the posts, its so easy to do.
hubbardybubbardy
  • West Midlands
« Reply #3 on: 12 July 2009, 15:33:16 »
Just one thing, I am unsure whether it will show gear box faults, certainly engine faults will show, maybe someone else will know to confirm this.  All the best with it anyway I know how frustrating it can be.
« Reply #4 on: 12 July 2009, 15:33:41 »
Hell there
It will only do engine faults though, it could still be a gearbox fault that the car is complaining about.  :y :y
bootyboy2006
« Reply #5 on: 12 July 2009, 18:15:30 »
Thanks to all for advice, here's hoping it is something simple!
« Reply #6 on: 12 July 2009, 18:21:58 »
If you fill in your details on your profile, there could very well be someone local to you who can help with diagnostics &/or repair.  ;) ;) ;)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #7 on: 12 July 2009, 18:49:22 »
The auto gearbox on my 2001 3.2 V6 was behaving oddly including one instance of causing a limp mode condition. Gearbox Service alert came up on the "pedal test" (which my car has but do not think that yours does). Gearbox fluid turned out to be low and so fluidand, gaskets and filter have been changed. Fingers crossed this has solved it.
There is a "how to" on the maintenance guides as to how to check the gearbox transmission fluid
