Author Topic: tyre size  (Read 1987 times)
JK
  • EASINGTON LANE
tyre size
« on: 12 July 2009, 17:14:47 »
I am after a bit of advice about tyre size for my omega elite 3.0 .The tyres that are on are the standard size,and are all due to be replaced, i do have in my garage 4 brand new tyres that i have had for some time ,i bought them for my peugeot 307 sw, but they are not exactly the same so i was wondering if i would be able to fit them on my omega ,the tyre sizes are 205/60/16 many thanks JK
i'm not fat,i just have a slipped chest
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: tyre size
« Reply #1 on: 12 July 2009, 17:31:55 »
15 inch wheels take 195 - 205-65-15's
16 inch wheels take 205 / 215/ 225- 55-16's
if you go to 60's i'm pretty sure it will screw up your speedo  :'(
JK
  • EASINGTON LANE
Re: tyre size
« Reply #2 on: 12 July 2009, 18:30:13 »
thanks for your quick reply, have you any idea how far the speedo will be out when 60 tyres are used instead of 55---thanks JK
924boy
  • Rhuddlan, N. Wales
Re: tyre size
« Reply #3 on: 12 July 2009, 18:32:48 »
205 = tyre width (mm)
60 = profile of tyre wall based on % of tyre width
60% of 205 = 123
if its ok to fit 225/55's (123.75) then 205/60's would be fine as the diameter / circumference is virtually the same.
This is as long as 215/55's are ok as said above!
hope this helps a little...  :-/
JK
  • EASINGTON LANE
Re: tyre size
« Reply #4 on: 12 July 2009, 18:50:51 »
I don't under stand where the 215s come in but i do understand that the 205 diameter is 0.75 larger, so it would be ok to fit 205/60 ,instead of 225/55 ,both are obviously 16 inch --JK
« Last Edit: 12 July 2009, 18:54:53 by johnkarl »
924boy
Re: tyre size
« Reply #5 on: 12 July 2009, 19:27:47 »
oops, when i put 215 at the end of the last post i meant 225... sorry  :-/
JK
  • EASINGTON LANE
Re: tyre size
« Reply #6 on: 12 July 2009, 19:33:29 »
Now i understand, many thanks,---JK :y
