Author Topic: Brown Gunk instead of coolant!! Knackered Engine??  (Read 4636 times)
Tointon
« on: 10 July 2009, 17:47:43 »
My 2.5 V6 very suddenly overheated.
I stopped and lifted the bonnet to find a Brown gooey type of gunk where their would normally be coolant.
The car seems to be running ok with no major noises or drop in power. I've heard this can be oil cooler problem rather than head gasket and subsequently a knackered engine?
Anyone had this problem?
Any help or advice would be really appreciated.
Thanks
Dan
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Brown Gunk instead of coolant!! Knackered Engine??
« Reply #1 on: 10 July 2009, 17:49:31 »
Thanks
Dan
head gasket rare on v6 mate so good chance its the oil cooler  :'(
ScottieMV6
  • Swinton, Manchester
« Reply #2 on: 10 July 2009, 18:13:04 »
I would say definitely oil cooler. Just had the same problem with mine.
Get a new oil cooler kit (around the £125 mark IIRC) and there is an excellent how to guide on here! :y
Whatever you do DON'T EVEN START THE CAR UNTIL IT IS SORTED!!!! :y
« Last Edit: 10 July 2009, 18:14:02 by scottie7275 »
I'd rather be scared to death than bored to death!!
psl
  • New Malden (Surrey)
« Reply #3 on: 10 July 2009, 18:27:28 »
same happened to me all done now, heres the guide http://www.omegaowners.com/forum/YaBB.pl?num=1221081908
and I found this usefull when ordering parts http://www.omegaowners.com/forum/YaBB.pl?num=1211220529
psl
« Reply #4 on: 10 July 2009, 18:29:02 »
its also a good time do do the cam cover gaskets if you think they need doing :y
ScottieMV6
« Reply #5 on: 10 July 2009, 18:52:03 »
Agreed  :y
And the thermostat!  :y
A word of advice. Don't scrimp and try reusing any of the bolts or washers. I found this out the hard way and had to re do them. 2 new cooler bolts and 4 washers and 2 new coolant bridge bolts and 4 washers is definitely a must IMO.  :y
« Last Edit: 10 July 2009, 18:53:33 by scottie7275 »
psl
« Reply #6 on: 10 July 2009, 19:00:29 »
if you do do the thermostat whilst doing your oil cooler (as I did) the bolt securing the coolant tranfer pipe is called the Ba***ard bolt with good reason, good luck :y
ScottieMV6
« Reply #7 on: 10 July 2009, 19:09:16 »
I didn't find it as hard as I had imagined it was going to be. I used a 10mm spanner on it which worked fine.  :y
« Reply #8 on: 10 July 2009, 19:20:32 »
oil cooler as said. Basic rule for the omega(for every rule there is always an exception but....)
oil in water, oil cooler.
Water in oil head gaskit.
Simples. :-)
Some very valid points re other parts while your in there but for me personally i wouldnt bother changing any other unrelated items(unless needed of course). Once you have had the plenum off once or twice its really not that hard a job to remove the manifold and inlet to get to the v where the oil cooler lives, and first time out i would leave the bastard little bolt well alone imho. Up to you and your wallet though.  :-)
« Last Edit: 10 July 2009, 19:26:56 by chrisgixer »
« Reply #9 on: 10 July 2009, 19:25:07 »
ps before you start cooler make sure you can gets the oil pipes by filter undone first. You WILL need crows feet or flair nut spanner for these, access is a bit ltd. Dont want to get that far only to find the shops are shut or whatever. Hth.
Tointon
« Reply #10 on: 10 July 2009, 20:35:37 »
Great response thanks!! Really helpfull.
I'm having this done by a local mechanic but I guess the best solution is to provide the parts and these guides which are amazingly well put together.
The last part of the puzzle is the best place to order up parts. Is this a straight Vauxhall only situation, or is there a better place to look? Automate? Internet?
Thanks again!
« Reply #11 on: 10 July 2009, 22:14:32 »
Vx only, got a special price for all parts (excluding oil and filter) today from my local (trade prices)....100.08 inc
« Reply #12 on: 10 July 2009, 22:15:48 »
That is a stunningly good price :o
« Reply #13 on: 10 July 2009, 22:19:07 »
Indeed, might try to get a few more.....that was for seals, sealent, kit and antifreeze
« Reply #14 on: 10 July 2009, 22:50:18 »
At that sort of price, I'd probably get one to keep in garage for that inevitable day...
