Author Topic: Gearbox Smoking!!!!  (Read 2361 times)
pfj101
  • Halesowen, West Mids
Gearbox Smoking!!!!
« on: 03 July 2008, 17:12:18 »
Hi folks,
Despite all the other problems I am trying to deal with my Omega at the moment, smoke started coming out of the centre cosole tday whilst sat i McDonalds, so bad I called the Fire Service because I thought it was about to go up! :'(
The auto box fuse has blown a few times, but this time just melted into a gooey red glob (10 amp). The airbag light has also come on as well, so I am assuming the 'fire' has taken that out with it.
Has anyone had this happen to them, and what advise, besides as the fireman said 'keep wafting it and we will fill it with water if you like'....He was jiking I hasten to add....
Thanks
Phill
You are never as good as you think you are, and never as bad as other people say you are.
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
Re: Gearbox Smoking!!!!
« Reply #1 on: 03 July 2008, 17:21:39 »
 :o :o Christ!! Dont sound too good mate! Sorry I cant help!  ::)
pfj101
« Reply #2 on: 03 July 2008, 17:26:00 »
It didnt amuse me at the time I can tell you..... >:(
It is driving in limp mode at the moment with no evidence so far of a repeat performance.
Thanks for your thoughts...I need them if I am to persevere with this beast.
P :-/
psychnurse
« Reply #3 on: 03 July 2008, 17:45:34 »
Im sure one of the guys will be able to offer you some sound...and reassuring advice. Sorry I cant... Im a bit of a mechanophobe!!  ;D
pfj101
« Reply #4 on: 07 July 2008, 19:33:11 »
Obviously this is a tricky one then. Anyone any clue......please.... sob......sob :'(
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #5 on: 07 July 2008, 23:50:48 »
How do you know it was the gearbox that was smoking?
« Reply #6 on: 07 July 2008, 23:54:30 »
My guess would be a selector "short" .. its electrical (fuse blown) and there's little else going to the autobox !!! I don't know what other wires run in the vicinity but that is probably the cause of the airbag like ... secondary action
pfj101
« Reply #7 on: 08 July 2008, 10:00:51 »
The smoke was coming from the area of the transmission housing, but could be something else. I'm guessing it was because of the melted fuse.
Thanks again chaps :)
pfj101
« Reply #8 on: 08 July 2008, 10:03:22 »
Thanks for that, that sounds as good a reason as any i've got.
What is the solution to that then........(Braces himself for expensive answer)
Oh nearly forgot, when then box was working the Snow Start button was iluminated and stayed on although the box was not operating in snow mode.....if that helps ny?
Thanks
Phill
« Reply #9 on: 08 July 2008, 10:35:24 »
is it the snow mode switch on pas side of g box? gets clagged up? any leaks in that area to cause short and smoke maybe? anyone?
« Reply #10 on: 08 July 2008, 10:41:10 »
I would say first task is to unplug all the connectors from the gearbox and inspect the length of loom that runs around the 'box for damage. Maybe that'll give you a clue what happened. I suspect you'll find a burnt wire or two and by matching colours / pin numbers with the wiring diagrams we may get an idea what's happening. Might also be worth looking out for a 2nd hand section of that loom as you'll priobably have to graft a new section in if it's damaged.
« Reply #11 on: 08 July 2008, 11:58:12 »
Has the radio been removed recently?
Do the wires look ok around the selector leaver (remove the leather cover)
pfj101
« Reply #12 on: 14 July 2009, 17:35:56 »
Sorry for the delay in replying got totally side tracked with a death in the family.
The radio has been in & ot recently, but all connections are ok.
No water ingresss around the gearbox/selector area so I think thats ok.
Engine has been spluttering and I suspect HBV dripping onto the Dis Pack, but would this cause a short in the gearbox I wonder?
What do you think?
MutantCav
  • Gainsborough
« Reply #13 on: 14 July 2009, 22:12:38 »
As a suggestion why not lift the gear selector gaitor and unplug the winter mode switch to see if that sorts the problem...if it went wrong just before the problem started then it may be worth a go :y
