Author Topic: The Truth About The Pedal Trick  (Read 3409 times)
swamp rat
  • Cornwall
« on: 15 July 2009, 18:52:17 »
At the risk of being severely berated, opinions please on what the pedal trick actually works on. It's stated on here so many times that it does not work on a 2.2, but I know for a fact that it works on mine because I've done it. I was led to believe that it works on any engine with the drive by wire (throttle with no cable). Anybody going to back me up here who has also flashed the codes off a 2.2
Re: The Truth About The Pedal Trick
« Reply #1 on: 15 July 2009, 18:55:28 »
ive tried it on 3 2.2's  and none of them worked.
So as far as I can tell..
3.2 & 2.6 Always work
2.2 may work apparently.
« Reply #2 on: 15 July 2009, 18:56:50 »
also, where all 2.2's should work with any generic obd code reader, ours didnt.
May be related.
May be several 2.2 ECU types / revisions
« Reply #3 on: 15 July 2009, 20:16:08 »
Thats interesting :y
Might go and put a fault on tunnie's 2.2 when hes not looking, and try that ;D
unlucky mark mv6
  • tipton,west mids
« Reply #4 on: 15 July 2009, 21:09:16 »
Thats it im sending him a pm and grassing you up. ;D ;D
« Reply #5 on: 15 July 2009, 21:10:24 »
wondering if some faults dont allow the pedal trick to work, for instance when fitting my lpg, i neglected to re plug in the dbw plug to throttle body. When turning the key for the first time, rather panicked with no pedal response, and pedal tricked to find the issue, light just went out, no flashing at all.
Remembered, after a sudden "comfort break", re plugged and all was well. Obviouse the pedal trick wont work if the drive by wire is unplugged as you have to press the gas pedal to perform said trick.
presume brake light switch is the same?
a mate has a fl 2.0 with breaked abs ecu that wont paper clip for instance , light just goes out as mine did, beleive its obd2 also??
So.... is it possible 2.2s have been tetsted with one of these faults in the past to find no flashing?..... But surely somone has tried it before now at some stage? Thinking about it, i am sure TB tested pedal trick at WIM Open day on a 2.2 after fitting cruise control, didnt work obviously.
ps, presume no fault will give constant flashing, so no need to induse a fault to test? ...but would be belt and brases i guess  :-/
also...im under the impression its ecu specific, rightly or wrongly?
« Reply #6 on: 15 July 2009, 21:10:45 »
Shame, you're so close to 500 posts   [smiley=evil.gif]
unlucky mark mv6
  • tipton,west mids
« Reply #7 on: 15 July 2009, 21:12:50 »
:-X :-X :-X :-X
deviator
  • Chesterfield
« Reply #8 on: 15 July 2009, 21:13:46 »
As said, no need to introduce a fault, the light should just keep flashing.
« Reply #9 on: 15 July 2009, 21:15:09 »
you're missing the point - i just want to break his car  :-X
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #10 on: 15 July 2009, 21:18:21 »
Well I've never tried it but I will just out of curiosity :)
Trade club card holder
Code scanner available
« Reply #11 on: 15 July 2009, 21:19:45 »
anyone know what works on a pre OBDII Rover MEMS3 ecu ::)
alexandjen
  • The Silver Surfer
« Reply #12 on: 15 July 2009, 21:31:47 »
Well well, just tried the pedal trick and the light constantly flashes showing no stored codes..........
Got a problem though..........led on fob is constantly flashing and the remote locking is not working, had to lock it with key in door......any suggestions?
« Reply #13 on: 15 July 2009, 21:47:43 »
flat fob battery? point at your head and press fob button. :y
« Reply #14 on: 16 July 2009, 07:54:26 »
Sammy  :y
Page created in 0.039 seconds with 20 queries.
