Author Topic: Changed Steering Column To Adjustable.  (Read 3101 times)
Pete Elite
  • Uxbridge, Middlesex
« on: 15 July 2009, 23:29:20 »
Hi all,
       I've just changed(a job I've been intending to do for quite a while now)the non-adjustable steering column on my 96 Elite for an adjustable one and what a difference it makes to the comfort and driving position :).
 I used the info. given in the maintenance section supplied by matchless([size=14]thanks matchless[/size]) which was very easy to follow and was a surprisingly straight forward job to carry out and well worth doing if your a bulkier chap such as me ::).
   On another matter, i haven't started the engine for about 3 1/2 months and would like to turn the engine over without it actually starting so as to push some oil round, so can someone let me know the best way to do this and if you think It's necessary :-/ :question.
         Thanks,
                    Pete.
Agemo
  • Cleethorpes
  • Insignia
Re: Changed Steering Column To Adjustable.
« Reply #1 on: 15 July 2009, 23:40:34 »
Glad the column job went well, they are brilliant. As for the turning over thing, I am sure it is a good idea,Use the starting handl - Oh no, we don't have thise any more!!!  I would have thought a spanner on the crank would be the best way. Any opinions?
« Last Edit: 15 July 2009, 23:41:19 by Agemo »
Toby
  • Ringwood, Hampshire
« Reply #2 on: 16 July 2009, 00:01:08 »
Can you not take your immobiliser chip out of your key?
Think the engine cranks but won't start
« Last Edit: 16 July 2009, 00:02:04 by Toby »
Pete Elite
« Reply #3 on: 16 July 2009, 00:01:59 »
Thanks Agemo, yes certainly a worthwhile mod.
 As for turning the engine over and using a starting handle, are you talking from experience, if so your showing you age now ;D.
 I was thinking because of the cats i don't want to just turn it over without it starting but still pumping petrol in to the cylinders, and was wondering if there was a way to do it :question.
        Thanks,
                   Pete :y.
Pete Elite
« Reply #4 on: 16 July 2009, 00:03:36 »
 As above Toby :y.
unlucky alf
  • worksop, notts
« Reply #5 on: 16 July 2009, 00:11:18 »
nice one on the column pete, i`ll be doing mine soon as im about to buy one, so was there anything that was a bit tricky?, ive still to locate the plastic cowling though so if anyone reading this can oblige :y & as for turning the engine over i would pull the fuse to the fuel pump :y
Toby
« Reply #6 on: 16 July 2009, 00:13:16 »
 As above Toby :y.
I see, I was under the impression that when the immobiliser kicked in it would cut the fuel supply. Fuse idea sounds better though  :y
Pete Elite
« Reply #7 on: 16 July 2009, 00:30:42 »
  Thanks Alf, Certainly was worth the effort and as for any tricky bits, taking the electric plug off from the left hand side of the column(round plug other end of ignition switch)place a flat bladed screwdriver or similar between joint(1st joint in from the left)and prise it apart a bit at a time, it will come off eventually :y.
  To remove the middle support bracket bolt i removed the instrument pod which made it a doddle to access :y.
  The sheer bolt i removed by just tapping it round with a cold chisel and removed it with my fingers after 1 full turn :y.
    HTH Alf :).
      As for the fuse do you know which one this is and is it under the column or the bonnet :question.
Pete Elite
« Reply #8 on: 16 July 2009, 00:33:00 »
 As above Toby :y.
       I'm not sure to be honest Toby but as you say Alf's idea of the fuse sounds the way to go, thanks anyway for your advise :y.
unlucky alf
  • worksop, notts
« Reply #9 on: 16 July 2009, 00:38:01 »
according to my handbook it says fuse 18 -20amp & cheers for the tip :y :y
Pete Elite
« Reply #10 on: 16 July 2009, 00:40:44 »
   Thanks for that Alf and hope you get on alright with your column change :y.
unlucky alf
  • worksop, notts
« Reply #11 on: 16 July 2009, 00:45:34 »
its me your talking about ;D, be prepared for another of my epic tales :D :D
Pete Elite
« Reply #12 on: 16 July 2009, 00:49:30 »
       Oh yeah, sorry Alf I'll await your full report ;D ;D.
   PS. If you weren't so far away i would have gladly come round and give you a hand, don't mind helping when i know what I'm doing(hopefully) ;D.
« Last Edit: 16 July 2009, 00:53:28 by scooby »
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #13 on: 16 July 2009, 09:30:42 »
Not knowing the full story , but why cant you start and run the engine  :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #14 on: 16 July 2009, 09:44:05 »
Good point about pulling the fuse, never thought about pumping fuel into the cats. I was also going to ask about why you don't want to run the engine. Oh and the starting handle - had one on my HA Viva, so yes, showing my age all right.
