Author Topic: overheating and oil!  (Read 1836 times)
ange4631
  • herts
« on: 16 July 2009, 15:09:02 »
please help, my 2.5 estate starting over heating about a month ago (been away 2 weeks) and started loosing a lot of coolant (top hose monut split that had been repaired but went again) then she began overheating.
after constantly topping her up she went into the red and broke down (this has happened a couple of times).
i have since tried to temp. repair this just to get me to and from work but, and she has not been driven more than a mile or two at a time since) she now wont hold the repair and when started now leaks oil around the edge of the bell housing (looks like its coming from quite high up, and checked, its not atf) on both sides, worse on the drivers side. any help in this would be much appreciated as i think i may be thinking its the HG, cheers in advance for your eagerly awaited replies!!
neilr
  • Barnet, Herts
Re: overheating and oil!
« Reply #1 on: 16 July 2009, 15:33:58 »
check for oil in plg well could be rocker cover gaskets have gone brittle through age and high temp of engine. also is there any gunge in water bottle could have suspect oil cooler.
ange4631
  • herts
« Reply #2 on: 16 July 2009, 15:38:57 »
coolant hasnt changed colour (even though it goes down quite quickly) will check oil wells!! (will i have to take plugs out, or just check the wells themselves)
how hard are they to replace, and would this cause this type of oil leak as i couldnt really see where the leak was coming from, when looking into engine bay, only from having a quick look from underneath!! (car unjacked)
« Last Edit: 16 July 2009, 15:39:53 by ange4631 »
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #3 on: 16 July 2009, 15:41:18 »
If you keep punishing you mig it could well be the HG so first have a look at what nielr said, if you can be sure its not them then you will have to check your heads. but dont drive it till you get it sorted or it could get that bad that you need a complet new engine.
He who brakes Looses
To old to die young
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #4 on: 16 July 2009, 15:43:01 »
If your Cam Covers are leaking you will more than likely have oil in the spark plug wells, plus oil can leak out of the back running down the rear of the engine to end up on the gearbox.
But if you have a water leak to that is something seperate I would think. Have you looked for a water leak? can you see none?
Daz
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #5 on: 16 July 2009, 15:43:48 »
Front drivers side plug leads is easiest to pull out and have a look in the plugwell :y
ange4631
  • herts
« Reply #6 on: 16 July 2009, 15:45:40 »
when i looked at her last, she looked like she had a little oil on the rocker cover, but thought it might have been me filling her up and missing. water is just leaking from the top mount as mentioned.
ange4631
  • herts
« Reply #7 on: 16 July 2009, 15:51:46 »
just had a look and there IS oil in the plug wells!!! how easy is it to sort that one, and how much?  :(
neilr
  • Barnet, Herts
« Reply #8 on: 16 July 2009, 16:28:29 »
there is a good how to in mainteance section its easy enough if you take your time can be done in an afternoon easily. but stop the water leak as mentioned i didnt and did lose the oil cooler but the bright side is i now have 2 migs one awaiting an oil cooler change. :-/
neilr
  • Barnet, Herts
« Reply #9 on: 16 July 2009, 16:30:06 »
euro car parts do payen gasket for about £10 i know some members will say dont use pattern parts but i didnt have problem with them
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #10 on: 16 July 2009, 18:09:03 »
Yet :o
Pattern Gaskets are not as good as genuine I'm afraid :(
KillerWatt
« Reply #11 on: 16 July 2009, 21:00:34 »
Yet :o
I agree.
Our MIG was fitted with pattern gaskets the first time around (before we owned it), it lasted 5 minutes (not literally, but you get the idea) before genuine Vx were used on the second occasion.
@ ange4631
Taking it in to the red will not do it any favours at all.
Stop crucifying it....just fix it before you do proper damage.
« Last Edit: 16 July 2009, 21:00:59 by KillerWatt »
ange4631
  • herts
« Reply #12 on: 17 July 2009, 10:30:03 »
dont worry, not even gonna fire her up until she's sorted, and thanks for all the help!!!!
ange4631
  • herts
« Reply #13 on: 17 July 2009, 15:10:44 »
done the cam cover gaskets and she seems ok at the mo, just the rad and 2 central silencers to go! lol
and then the dreaded MOT!
Page created in 0.021 seconds with 16 queries.
