Author Topic: My key fob stopped working!  (Read 2176 times)
SMD
  • London
    • :( nowt
« on: 18 July 2009, 20:11:48 »
My key fob wont unlock the car and when I use the key to unlock it the alarm keeps going off, and goes off when I put the key in the ignotion.
So first question is it the battery in the key fob thats dead?
And secondly why does the alarm go off when I use the key to unlock the door? I removed the bonnet switch (FWIW when I had alarm issues)
Ta
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: My key fob stopped working!
« Reply #1 on: 18 July 2009, 20:14:10 »
you need to change the battery mate, dont loose the chip so be carefull doing it.
Your alarm will go of untill you unlock the car with the fob.
He who brakes Looses
To old to die young
SMD
  • London
    • :( nowt
« Reply #2 on: 18 July 2009, 20:18:53 »
what type battery and where can i get it from?
any thing i need to be aware of when replacing it?
« Reply #3 on: 18 July 2009, 20:23:50 »
The battery is a CR2032, available from stockists of batteries, and I know W.H.Smith sell them for one. ;)
Just make sure you don't do what I did once with one of these and push the battery against the black clip at it's rear, as the battery MUST go UNDER it.
The alarm will go off if you use the key manually in the lock, but once you start the engine it should cease. ;) ;)
SMD
  • London
    • :( nowt
« Reply #4 on: 18 July 2009, 20:49:58 »
just one more thing, how do i get it open? just tried to take the battery out of my spare (faulty) key but decided to ask first before i break something. i noticed it opens at the front, where the buttons are. is this correct?
i say this key is faulty because when i lock it via remote the alarm keeps going off!
« Reply #5 on: 18 July 2009, 20:54:26 »
Look to see if the red LED flashes on the fob cover when you press the buttons. ;)
« Reply #6 on: 18 July 2009, 20:55:42 »
Is your fob two or three buttoned? :-/
SMD
  • London
    • :( nowt
« Reply #7 on: 18 July 2009, 21:03:48 »
two buttons.
just tried what you pressing the buttons on the spare key but no flashing LED. was working only a few days ago
« Reply #8 on: 18 July 2009, 21:07:56 »
two buttons.
That does sound like batteries have gone then ;).
I have a three button fob, and with mine the main key shaft section comes away after you push a small screwdriver into the little opening on the back of the fob just above the blade.  You then pull apart the two sections of the rest of the key fob, being carefull not to dislodge and lose the chip attached to the side of one of the two sections. The battery can then be carefully removed by lifting on the side opposite the black clip that the battery sits under on that side;) ;)
« Last Edit: 18 July 2009, 21:09:23 by Lizzie_Zoom »
leejd666
  • rotherham
« Reply #9 on: 26 September 2013, 15:30:16 »
erm well thanks for this advise someone has also done this :\ at least its not just mee !
« Reply #10 on: 26 September 2013, 16:06:57 »
Thats another oldie dragged up!!  (2009!!)
Shows you how to change key battery page 53 Owners Handbook ;)
