Author Topic: Engine light  (Read 2247 times)
westo123
Engine light
« on: 15 July 2009, 16:16:57 »
We have just bought a 2000(W) Omega CD Estate manual 2.0lt.
During the few trips we have done, the engine comes on every so often, stays on for a while then goes out.
I have searched and found the normal tricks with diagnostic plug to get the fault codes but as this is a 2000 they do not work. Does the pedal trick work with this year or do I have to bite the bullet and pay VX.
Or do we have someone local who could assist, as I think the cam belt could do with a change as well!
Omega man 2
Re: Engine light
« Reply #1 on: 15 July 2009, 16:18:28 »
The paperclip should work with the 2.0. its the 2000 2.2 that it doesn't work on :y
westo123
Re: Engine light
« Reply #2 on: 15 July 2009, 16:28:35 »
I understood it was only cars up to 1999, as in this thread
http://www.vauxhallownersnetwork.co.uk/showthread.php?t=87821
post number 2
Is that not right?
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: Engine light
« Reply #3 on: 15 July 2009, 16:36:16 »
No the paperclip test should work mate have a look at the link and you can see how to do it, you might have just got the wrong hole.
www.omegaowners.com/forum/YaBB.pl?num=1189022687
Have another go and see if anything comes up. :y
He who brakes Looses
To old to die young
westo123
Re: Engine light
« Reply #4 on: 15 July 2009, 16:43:35 »
Ok thanks I 'll try again tomorrow.
I did do it before I saw the link saying about post 1999 cars and connected A and B but nothing happened.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Engine light
« Reply #5 on: 15 July 2009, 18:02:18 »
Check to see if the engine light bulb has not been pulled out to hide the gearbox fault. it should ccome on when you turn the ign key and go out a few sec after the engine is started. if no light then no bulb. ::)
OOPS just read the post again light comes on now and again. Sorry. must get to spec savers real soon. :o
« Last Edit: 15 July 2009, 18:06:02 by ffcgary1 »
Jaguar XJ6
westo123
Re: Engine light
« Reply #6 on: 18 July 2009, 11:21:33 »
Well I've had another go with both the paperclip test; connected A and B and turned ignition on, no flashes and the pedal test, still no flashes.
Still the engine comes on every so often and stays on for a while.
Can anyone please tell me why?
The car is a 2000 (W) Omega Estate CD Petrol manual 2.lt and shows nothing wrong on the dashboard information display screen.
westo123
Re: Engine light
« Reply #7 on: 19 July 2009, 10:32:02 »
bump
