Pages: 1 2 [3]  All   Go Down
Author Topic: Rear doors dont unlock!!!!  (Read 6269 times)
ians
  • Reading
Re: Rear doors dont unlock!!!!
« Reply #30 on: 20 July 2009, 17:19:27 »
I don't think its the lock solenoid at fault as the electric window is also not working.
Anthony
  • Launceston, Cornwall
« Reply #31 on: 20 July 2009, 19:01:50 »
hi all, ok i have been looking at all the wires and had a fiddle with them as they all looked good, now the window works :D :D :D but the door still doesn't :'( :'( tried to pull up the knob but still no luck. just tried the key fob on position 2 and no joy, looks like the solinod :'( :'( thing is i cant get the door open to change it :'(
Thanks
Anthony
Anthony
« Reply #32 on: 20 July 2009, 19:03:39 »
oh forgot to say i can now hear the lock moving in the door!!!!!! but the handle won't work. so maybe not the solinod. basically i have no idea ;D ;D ;D ;D ;D ;D
Cheers
Ant
x.ray
  • walsall west mids
« Reply #33 on: 20 July 2009, 19:06:01 »
just pulled mine up again with pliars.
you will be able to open the door.
let me know how you get on changing the solinoid as i have got to try to do mine
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #34 on: 20 July 2009, 19:48:37 »
had problems with my locks last week  :'(
if you recycle the locks using the key ( too deadlock ) a few times, it should sort its self out like mine did  :y
if you have pulled the wires around and now things are starting to work then thats your problem  :y
geoff
  • thornaby,stockton on tees
« Reply #35 on: 21 July 2009, 08:52:33 »
try dissconnecting battery and reconnect again after a few secs and see if it will manuallly unlock,mine did this a few years ago,mine locked me out and sun roof opened,could not open doors with key as it was dead locked,when connected battery it let me open dorrs again with no dead lock on must have reset doors,but don't forget to reset windows and roof  :y
Anthony
« Reply #36 on: 21 July 2009, 10:47:13 »
Tried this and still no joy :'( :'( :'(
Also volt checked the battery and it only has 12.4V. i think i remember that anything less than 12.6V meant a flat battery. i looked at the sight glass thing on top and it is black. could this be part of the problem.
Anthony
Spearmint
  • Corby
« Reply #37 on: 21 July 2009, 11:28:25 »
Did you check the battery with the engine off? If so that is a good value.
Did you try my suggestion? It'll take you only a few seconds and it is free......
Pages: 1 2 [3]  All   Go Up
