Pages: [1] 2 3  All   Go Down
Author Topic: Rear doors dont unlock!!!!  (Read 6279 times)
Anthony
  • Launceston, Cornwall
« on: 15 July 2009, 10:09:56 »
hello everyone,
I just went out to the car and the rear drivers door won't unlock i.ve tried to pull the knob up but it will not move, also won't work using the key.  has anyone got any ideas?
Thanks in advance
Anthony
Agemo
  • Cleethorpes
  • Insignia
Re: Rear doors dont unlock!!!!
« Reply #1 on: 15 July 2009, 10:18:15 »
If it was one door I would say it was the solenoid, but being two, I suppose it has to be wiring. Have you disturbed anything lately? Have you got power to the doors (windows etc.)  Have you tried both switches?
Anthony
« Reply #2 on: 15 July 2009, 10:24:48 »
Thanks for replying, i haven't done anything other than putting the child lock on.just checked the windows both switches don't work. am i just looking at a blown fuse?
Anthony
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 15 July 2009, 10:37:30 »
I am sure front & back are on the same fuse, worth checking though.  ::)
Agemo
  • Cleethorpes
  • Insignia
« Reply #4 on: 15 July 2009, 10:40:18 »
Just looked, fuse 20 covers all doors - 20 amp yellow fuse. Fuse 7 covers rear windows - 30 amp.
Anthony
« Reply #5 on: 15 July 2009, 10:44:14 »
cheers for looking it up for me, must be a elec supply prob then? off to the garage me thinks.
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 15 July 2009, 10:46:39 »
Hmmm, sounds a bit technical, just to confirm then:-
Front windows work perfectly.
Rear windows will not operate with either switch.
Rear doors are both locked.
All fuses OK.
Sorry mate, I am not a lot of help.
Agemo
  • Cleethorpes
  • Insignia
« Reply #7 on: 15 July 2009, 10:50:38 »
Are the rear windows isolated by the switch on the driver's door?
Anthony
« Reply #8 on: 15 July 2009, 10:53:25 »
front doors perfect
NSR Door perfect.
OSR Door problem.
Fuses fine.
All windows apart from OSR work on both switches.
Sorry if i wasn't clear before
Thanks
Anthony
« Last Edit: 15 July 2009, 10:54:14 by swiss239 »
Agemo
  • Cleethorpes
  • Insignia
« Reply #9 on: 15 July 2009, 10:56:11 »
OK, so you have one door that does not open?
It does sound like a connection or a solenoid, probably the plug going into the door, (the one you need the door open to get to).
« Last Edit: 15 July 2009, 10:56:52 by Agemo »
Agemo
  • Cleethorpes
  • Insignia
« Reply #10 on: 15 July 2009, 11:00:30 »
Whatever the problem is, the button should be able to be pulled up. It seems the door is deadlocked.
I did not read your first post right, thought it was two doors, sorry my fault.
« Last Edit: 15 July 2009, 11:00:52 by Agemo »
Anthony
« Reply #11 on: 15 July 2009, 11:02:05 »
always the way, do you know if you can force it open to check?
Agemo
  • Cleethorpes
  • Insignia
« Reply #12 on: 15 July 2009, 11:05:10 »
You will have to get the door card off, it may be damaged, but better than damaging a door, and cheaper to replace.With the door card off, it is a simple job to replace the solenoid, but if it is the wiring elsewhere, you would have to get the door open from the inside somehow. I hope someone on here has experience of this. You may well have to wait until tonight.
Anthony
« Reply #13 on: 15 July 2009, 11:10:37 »
thanks for your help
ians
  • Reading
« Reply #14 on: 15 July 2009, 11:46:38 »
It sounds like the power to the door is dead.
Should the child lock prevent pulling the knob up? :-/
It would definitely help if you can get the door open - may need some force.
(your title says doors plural, hence some confusion)
Pages: [1] 2 3  All   Go Up
