Author Topic: drop-links  (Read 1339 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
drop-links
« on: 24 July 2009, 13:09:00 »
need to replace n/s drop link. is it adviceable to do both sides.   :)
KillerWatt
Re: drop-links
« Reply #1 on: 24 July 2009, 13:11:45 »
You should ALWAYS change suspension & braking components in pairs
raywilb
    • Citroen C4 Cactus
Re: drop-links
« Reply #2 on: 24 July 2009, 13:27:43 »
will do. thanks  :y :y
Re: drop-links
« Reply #3 on: 24 July 2009, 13:54:02 »
yes, both together
raywilb
    • Citroen C4 Cactus
Re: drop-links
« Reply #4 on: 24 July 2009, 14:52:33 »
thanks guys, will do :y
dippydave
  • Sutton Coldfield, West Mids
  • how personal?
    • Vectra 2.0DTi Elite
Re: drop-links
« Reply #5 on: 24 July 2009, 18:16:42 »
I just replaced both mine, and apart from the nuts being a bit awkward to start with, it was a pretty simple job.
I used these:
http://www.buypartsby.co.uk/steering-and-suspension-final.php?year=1999&Submit=Next&make=Vauxhall&model=Omega&sub=&eng=2.5000
6.22 + vat each.  :y
and used this maintenance guide:
http://www.omegaowners.com/forum/YaBB.pl?num=1152986949
Mostly because I was also swapping the suspension arms!
Probably this photo and some spanners is all you'll need:
http://www.omegaowners.com/forum/YaBB.pl?num=1219190177
Oh and axle stands too  :y
Vectra Elite Estate doing good post-Omega service but still not as nice to sit in.
One last Omega on the drive, one Corsa on the lawn...maybe they'll go to a good home before too long!
