Author Topic: V6 DIS pack  (Read 1432 times)
Dubious
  • Nearer Swindon than Brisbane
V6 DIS pack
« on: 24 July 2009, 10:12:02 »
(2.5 V6 with the horizontal DIS pack) I've carefully labelled the wires, but want to make sure I put them back in the right sockets.
Is it 1,3,5,6,4,2 counted clockwise from the connector ?
Thanks.
Re: V6 DIS pack
« Reply #1 on: 24 July 2009, 10:27:42 »
Nope...
Its 135 - 462
as per:
Dubious
Re: V6 DIS pack
« Reply #2 on: 24 July 2009, 14:50:19 »
Thanks for that, but mine has the connector at the end of the dis pack, and it plugs in parallel with the leads.
I now think it might be 5 3 1 4 6 2, clockwise from the connector. Does that sound right ?
Thanks.
johnboy27
  • cleveland
Re: V6 DIS pack
« Reply #3 on: 24 July 2009, 19:33:30 »
Does it not have the numbers on it. or is it already fitted & you cant see it. i remember changing mine & it been very fiddley & working by feel rather than sight
Dubious
Re: V6 DIS pack
« Reply #4 on: 24 July 2009, 20:45:47 »
It's still installed, and I can't get close enough to see the numbers. I've managed to get a picture off fleabay on which I can see some of the numbers, and did record my 1,3,5 when I took them off so I know those.
johnboy27
  • cleveland
Re: V6 DIS pack
« Reply #5 on: 24 July 2009, 21:04:00 »
Fingers crossed then eh.
Good luck, i know how bad they are to get to.
Have you removed the plastic scuttle panel & wiper motor to give better access
Dubious
Re: V6 DIS pack
« Reply #6 on: 24 July 2009, 21:51:45 »
Yes - the scuttle and wiper motor were the easy bit !
I might have another go at getting the DIS pack out to check it and the numbering, but I've really struggled with the last bolt.
johnboy27
  • cleveland
Re: V6 DIS pack
« Reply #7 on: 25 July 2009, 09:17:12 »
they are a nightmare. i knew i had fit one on v6 vectra once so thought it would be similar job then i remembered the vectra engine sits the other way round. prop took 3 or 4 times longer
