Author Topic: Warning lights  (Read 1533 times)
bighed
  • Shropshire
Warning lights
« on: 25 July 2009, 22:15:54 »
Hi guys, shortly after i set of for work this afternoon, both the ABS and traction control lights came on. I pressed the brake pedal and they went off. This also happened about 3 days ago, again pressing the pedal turned them off. It has started since I have had to drive down really crappy lanes as main road to work is closed. Any ideas please??  :y
« Last Edit: 25 July 2009, 22:17:00 by bighed »
Re: Warning lights
« Reply #1 on: 26 July 2009, 14:58:53 »
If you have access to a decent code reader, worth seeing what the ecu thinks, though if its post 1998, ecu failure is a possibility
bighed
  • Shropshire
Re: Warning lights
« Reply #2 on: 26 July 2009, 21:26:01 »
Its a 1999 2.5 V6, I will paperclip it tomorrow see what codes it chucks up.
