Author Topic: Air bag warning  (Read 1146 times)
amba
  • Medway towns
    • German V6
Air bag warning
« on: 26 July 2009, 21:43:59 »
My steering wheel is not dead straight and this has bugged me for ages.If I remove the steering wheel and disconect the air bag will I then need it reset with a tech 2.../ or is there a clever trick by disconnecting the battery for a few hours first and then putting it back together when all reconnected.
Re: Air bag warning
« Reply #1 on: 26 July 2009, 21:53:31 »
Just don't turn the ignition on with the air bag disconnected.
amba
  • Medway towns
    • German V6
Re: Air bag warning
« Reply #2 on: 26 July 2009, 21:56:48 »
So if I disconnect the battery for a few hours..then remove steering wheel and reposition and fit all connections back..then reconnect battery,and only then turn on ignition I will NOT require the air bag light resetting?
Re: Air bag warning
« Reply #3 on: 26 July 2009, 21:59:11 »
Correct! but you don't need to leave it hours before you start work .... 10 - 15 mins I think.
Thing is though, why isn't your wheel straight? It could be a part of the steering that's bent and is causing your wheel not to be in the sttraight head position.
Re: Air bag warning
« Reply #4 on: 26 July 2009, 21:59:19 »
In theory .....   ;)
Please note .. all advice given is advisory and is listened to at the risk of it not working................    ;D ;D ;D
amba
  • Medway towns
    • German V6
Re: Air bag warning
« Reply #5 on: 26 July 2009, 22:05:08 »
Mechanic removed steering wheel few years ago as I had a nasty grating from steering coloumn..this was replaced but he didn,t get the wheel back on dead straight..has been like it few long time now,but it bugs me and I have some spare days in the next few weeks so will correct it..just wanted to be sure wasn,t creating extra work and expense with air bag light
Re: Air bag warning
« Reply #6 on: 26 July 2009, 22:08:58 »
Mechanic removed steering wheel few years ago .....this was replaced but he didn,t get the wheel back on dead straight.. ......
I keep saying I'll straighten my Astra's wheel - similar reason - but that's as far as I get!  ;D  ;D
Disconnect your battery & go & have a brew/ciggy, you'll be fine!  :y
Page created in 0.044 seconds with 16 queries.
