Author Topic: Upgrading my brakes - Advice needed please  (Read 1386 times)
SJKOO01
« on: 25 July 2009, 20:24:47 »
Hi.
I'm looking to upgrade the brakes on my car.
Obviously can't afford (or see the point) a hub / disc upgrade from the likes of AP, brembo, or such like.  But thought that going the route of upgrading with something like 3.2. V6 calipers & discs all round, along with braided hose maybe a good idea ?.
Anyone have any advise or thoughts on this route ?.
M
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Upgrading my brakes - Advice needed please
« Reply #1 on: 25 July 2009, 20:40:49 »
Properly maintained standard Mig brakes should be more than enough.
If yours are a bit tired, new discs and something like EBC "Green Stuff" pads should sort it.   :y
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #2 on: 26 July 2009, 01:36:01 »
All the omegas after about 95 where fitted with the larger dia discs and did not change for the 3.2. you can however use upgraded pads and when you go to vx ask for police pads, they are slightly softer compound to std pads but perform much better. that is all you have to do. dont waste your money on differant calipers as they wil not give you much more than you already have. :y
Jaguar XJ6
sparkyw666.
  • aberdeen uk
  • aka mark w
« Reply #3 on: 26 July 2009, 12:25:24 »
yip ebc green stuff pads work good  :y
v6 cam locking kit  member:y
« Reply #4 on: 26 July 2009, 12:40:01 »
can vouch for oe pads as fitted from the factory made by Jurid ( as opposed to aftermarket/trade club pads ) improved bite and feel, but are over 3 times the price.
SJKOO01
« Reply #5 on: 26 July 2009, 16:36:13 »
Thanks for the advise, obviously an easier mod than I thought it would be.
I'll get some uprated 'Quality' pads then.
Cheers
M   :y
« Reply #6 on: 26 July 2009, 16:40:56 »
All the omegas after about 95 where fitted with the larger dia discs and did not change for the 3.2.  .....
NearlY!  ;) Later cars, from around when the 2.6 & 3.2 appeared, received vented disc at the rear.  :y  :y
omegaman1973
  • Great dunmow, Stansted
« Reply #7 on: 26 July 2009, 16:46:20 »
HI Andy do you know if those rear vented ones would fit a elite 99 a 2.5 mini face lift?
mine are comingto the end of their life and if i could change for one of thoses, i'm thinking of taking "the beast" to Portugalnext year and damn it's hot out there and some performance in the heat would be nice :)
Live long and prosper, buy a mig.
« Reply #8 on: 26 July 2009, 16:52:06 »
I can't any reason why not. Obviously you'd need the calipers to go with them.
You're not likey to see any great benefit though, standard rear solid are up to the job.
ffcgary1
  • Mitcham,Surrey.
« Reply #9 on: 27 July 2009, 00:25:06 »
I was assuming that you were talking about front discs that you were thinking about upgrading. SORRY. I took my car to spain last year and we had 40deges and the std vx pads were more than capable. Upgrading the rears to vented discs will not improve  above your std setup.
Jaguar XJ6
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #10 on: 27 July 2009, 00:48:26 »
You may also get brake bias imbalance. You'll notice the ABS system kicking in more often as the rear wheels will be more prone to lock up under heavy braking. Personally I don't see the point in making the ABS work harder for no gain.
Page created in 0.025 seconds with 16 queries.
