Author Topic: Power Steering  (Read 1722 times)
DOC23
Power Steering
« on: 27 July 2009, 22:30:17 »
hey i have a 97 mv6 and the power steering is really annoying me! the power steering only seems to work when i rev the engine, and if its just idling the steering is as heavy.
can anybody help?
cheers
daniel
Re: Power Steering
« Reply #1 on: 27 July 2009, 22:39:47 »
can anybody help?
cheers
daniel
Pump is probably on its way out. There are breakers here who'll be able  to sort you out with a 'new' one!  :y
 ...... and welcome to the OOF forum!  :y
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
Re: Power Steering
« Reply #2 on: 24 February 2012, 00:44:48 »
i Have the same issue but mine is intermittant.... some days works perfect others heavy as a tractor!
also seems clunky & knocky when stationary...
& sometimes on a rounderbout etc doesnt return to center...
what maybe the issue.... pump... fluid need changing... airlock...
Help please..  :(
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
Re: Power Steering
« Reply #3 on: 24 February 2012, 09:15:22 »
Help please..  :(
I was told when this happened on mine to try changing the fluid due to intermittant fault as it might clean out any sticking parts?
Can't remember exactly what was said. always good to try the cheaper option before changing parts but as Andy says there are plenty of breakers on here.  :y
www.impactcls.co.uk - Flight Case Manufacture
Zippy2012
  • Worcester uk
Re: Power Steering
« Reply #4 on: 27 February 2012, 12:58:59 »
Help please..  :(
is it easy to change the fluid?? where would i find the drain plug if fitted?? any body fancy giving me a hand??
Re: Power Steering
« Reply #5 on: 27 February 2012, 13:09:34 »
Drain the reservoir and fill with fresh fluid.
Disconnect the return pipe and place into an empty container.
Run the engine and steer lock to lock whilst keeping reservoir topped up as required until the fluid going into the empty container changes to colour of new
Zippy2012
  • Worcester uk
Re: Power Steering
« Reply #6 on: 27 February 2012, 13:11:59 »
Cheers i give that a go mate!!  :y
