Author Topic: Reffiting cambelt.  (Read 1613 times)
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
Reffiting cambelt.
« on: 27 July 2009, 20:01:55 »
Is it ok to refit the cambelt after 3.5k miles, while changing lifters? :-/
Assuming that it has to go on in the same direction and the setting on the tensioner has to be changed for used? :y
And yes, I know for a fact it has only done 3.5k because I done it :)
And no, I'm not a sheep ::)
« Last Edit: 27 July 2009, 20:02:27 by Brick_Tamland »
Saving for one! All donations welcome, ask for details.
Re: Reffiting cambelt.
« Reply #1 on: 27 July 2009, 20:04:19 »
should be fine :y
« Reply #2 on: 27 July 2009, 20:04:47 »
assuming all tensioners and riollers were also changed 3.5k ago
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #3 on: 27 July 2009, 20:06:32 »
Yep, thanks :y :y
sev
« Reply #4 on: 28 July 2009, 00:50:30 »
just make sure that you set the tensioner to the used setting rather than the full tension as you did for the new belt.
1995 2.5 V6 CDX Saloon
