Author Topic: 3.ol v6 cutting out hellllllllp  (Read 1724 times)
omega rod
  • falfield
« on: 28 July 2009, 18:15:00 »
hi i have been pulling my hair out with this fault.
right i bought car with cracked offside manufold, but car was running fine then about 2 weeks later car started cutting out,
if im doing 70 down the motorway or driving at 30 round town.when it cuts if i floor it after about 3 0r 4 seconds it fires up and is ok for 5 or 6 miles then does the same. sometimes all the dash lights come on and i have to put it in neutral and start it. the engine light does not come on.
i have changed the crankshaft sensor twice with no change. fault code 31 come on fault code but like i say i have fitted two crank sensors. i also hve oil lack come up randomly and coolent level. and some times the fuel gage shows nothing and then reads normal. hellllp. the car is a 96 3.0l v6 elite
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: 3.ol v6 cutting out hellllllllp
« Reply #1 on: 28 July 2009, 18:28:45 »
Have a look in the sparkplug wells, see if they are dry and not full of oil or water.
He who brakes Looses
To old to die young
omega rod
  • falfield
« Reply #2 on: 28 July 2009, 18:30:13 »
thanks they are dry
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #3 on: 28 July 2009, 18:31:50 »
Does it actually lose oil or coolant when its warning you about it?
And is the coolant clear or gunky?
« Last Edit: 28 July 2009, 18:32:07 by PeteG »
Ziad
  • Bahrain
« Reply #4 on: 28 July 2009, 18:34:34 »
Do you mean that the engine light NEVER comes on at all?? Are the crank sensors you fitted genuine Vauxhall ones?
I would recommend that you check your HT leads and DIS Pack as well
« Last Edit: 28 July 2009, 18:36:01 by ziad »
omega rod
  • falfield
« Reply #5 on: 28 July 2009, 18:35:36 »
no both are fine all is clean
omega rod
  • falfield
« Reply #6 on: 28 July 2009, 18:37:45 »
engine light works but has never come on when it cuts out.
i fitted none vaux sensors
Ziad
  • Bahrain
« Reply #7 on: 28 July 2009, 18:49:09 »
Maybe you could test it with a known working genuine sensor?
Ian_D
  • York
« Reply #8 on: 28 July 2009, 19:02:29 »
Have you checked the battery voltage with the engine running at idle, and then at say 3000rpm?
Wonder if its over charging and sending the electrics crazy?
[size=12]
omega rod
  • falfield
« Reply #9 on: 28 July 2009, 20:10:11 »
yes i have checked volts its at 13.5 practicaly constant when engine is running. could it be the mass air sensor?
