Author Topic: Door lock stuck!  (Read 901 times)
Ludvig
  • Uppsala, Sweden
Door lock stuck!
« on: 27 July 2009, 18:21:55 »
Help! I have a major problem.
On my -03 Omega the passenger side door lock motor broke down a few weeks ago. No big problem. A simple job to fix following these excellent guidelines http://www.omegaowners.com/forum/YaBB.pl?num=1152953579/0#0
Thank you, The boy!
Today I finally got around to trying to fixi it. To my great horror, I found that the lock is stuck in the extra safety position that bars the lock. This means that it is impossible to pull the knob = the door remains locked = I can't get to the screws holding the door panel = I can't get in to the locking mechanism. Catch 22.
Does anyone know how to get the lock out of the barred position manually?
Ludvig
  • Uppsala, Sweden
Re: Door lock stuck!
« Reply #1 on: 28 July 2009, 11:30:55 »
Problem solved! With a lot of patience and some brute force I finally managed to unlock the door. Now I can go ahaed and change the motor  :D (which cost a horrendous amount at the local Opel stealer  >:( )
Keep cruising!  :y
« Reply #2 on: 28 July 2009, 14:50:53 »
Keep cruising!  :y
Check the maint guide section, i made one on how to replace the motor  :y
Ludvig
  • Uppsala, Sweden
« Reply #3 on: 29 July 2009, 08:12:33 »
Yep, thanks to the guidelines on removing door card and replacing central locking motor this job was a piece of cake   :) Thanks guys for writing all the excellent guidelines!!  :y
If I had realised how easy the job is I would have taken the advise to buy the motor at the scrappy  ;)
Page created in 0.04 seconds with 16 queries.
