Author Topic: Help, engine light still comes on  (Read 1710 times)
westo123
« on: 25 July 2009, 09:20:48 »
I've had a go with both the paperclip test; connected A and B and turned ignition on, no flashes and the pedal test, still no flashes.
Still the engine comes on every so often and stays on for a while.
Can anyone please tell me why?
The car is a 2000 (W) Omega Estate CD Petrol manual 2.lt and shows nothing wrong on the dashboard information display screen.
johnnycboy
  • Colchester
Re: Help, engine light still comes on
« Reply #1 on: 25 July 2009, 10:21:26 »
reading your thread are you saying that the paperclip test did not work or you did not get any codes?
johnnycboy
  • Colchester
« Reply #2 on: 25 July 2009, 10:22:24 »
edit - mis read your thread :-[
Don't think you can paperclip 2lt, need codes read
« Last Edit: 25 July 2009, 10:22:44 by johnnycboy »
« Reply #3 on: 25 July 2009, 10:33:30 »
The paperclip test should work on a 2.0, did you have the right holes connected and was the ignition on but the engine off.
westo123
« Reply #4 on: 25 July 2009, 15:13:05 »
[/quote]
Don't think you can paperclip 2lt, need codes read [/quote]
That's what I thought but no one seems to know for sure.
Used A and B which I think is right and yes ignition on engine off
« Reply #5 on: 25 July 2009, 17:18:47 »
Used A and B which I think is right and yes ignition on engine off[/quote]
Counting from bottom of diag. plug. 3rd and 5th pins need to be bridged. :y Don`t know about A and B :-/
westo123
« Reply #6 on: 28 July 2009, 11:06:37 »
Counting from bottom of diag. plug. 3rd and 5th pins need to be bridged. :y Don`t know about A and B :-/[/quote]
Tried 3rd and 5th with the clip both up and down no change.
This site says A and B
http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
as does this one
http://www.makinterface.de/index_e.php3?frompage=/aldl_e.php3
I have also tried A and K.
Nothing makes any difference.
Nobody seems to have the definitive answer so
it looks like I need to get a dealer to do a tech 2 check.
« Reply #7 on: 28 July 2009, 17:35:30 »
as does this one
Try the REAL source of information ..
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
« Last Edit: 28 July 2009, 17:37:10 by entwood »
« Reply #8 on: 28 July 2009, 17:41:41 »
as does this one
Correct!   :y  :y  :y
Sometimes people can't see the nose on the front of their face!  ;D  ;D  ;D  ;D  ;D  ;D
westo123
« Reply #9 on: 28 July 2009, 17:52:24 »
That was the first place I looked but it's no good as my car does not have that diagnostic plug, mine is on the drivers side and has 10 pins.
Just booked it in to be checked and the cost is only £45!!
« Last Edit: 28 July 2009, 17:54:16 by westo123 »
« Reply #10 on: 28 July 2009, 18:37:21 »
They`re all on driver`s side on the omega ::). Like to see a pic of the plug you`re trying to `clip :-?
Shagma
  • Norway
« Reply #11 on: 28 July 2009, 23:40:42 »
If the engine light has been lit, but has gone off again...?
Could it be that there simply ARE no codes stored...?
MutantCav
  • Gainsborough
« Reply #12 on: 29 July 2009, 08:57:23 »
Diagnostics plug on all Omegas is the same looks wise...pin 4 and 6 on 2.5/3.0 v6's for paperclip pin 1 being top right pin then working down...not sure on 2.0
Post modified by TheBoy - I'm sick and tired of repeating the rather RULES  >:(
« Last Edit: 29 July 2009, 17:52:50 by TheBoy »
westo123
« Reply #13 on: 29 July 2009, 12:05:32 »
Ok thanks for all your help so far!
Did the test again probably using the correct plug this time!!
Came up with 10 flashes,1 flash, 3 flashes, 10 flashes which I think is 0130 and relates to the o2 sensor.
Is this all correct?
Had a quick look before the wife went shopping couldn't locate it.
Can you let me know where it is and how easy it is to change?
