Author Topic: 2.5TD Auto transmission fluid level check  (Read 1527 times)
Spearmint
  • Corby
« on: 28 July 2009, 18:13:55 »
Ok so I've just put the car back together and as the system which allows the oil from the gearbox to be cooled by the radiator was disturbed in the process I now need to check the level.
I take it this is like a normal gearbox for adding any fluid etc? Fill to spill through the hole on the side?
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: 2.5TD Auto transmission fluid level check
« Reply #1 on: 28 July 2009, 18:42:53 »
........with the car level & the engine running
Spearmint
  • Corby
« Reply #2 on: 29 July 2009, 11:08:38 »
Ok, level ground is understandable but why with the car running? Bear with me, this is my first Auto.
Pitchfork
« Reply #3 on: 29 July 2009, 14:55:55 »
so that the pump is running & circulating the fluid
