Author Topic: Dashboard Lights.  (Read 1255 times)
REvil71
  • Wales
    • 3.2 Elite Saloon
Dashboard Lights.
« on: 26 July 2009, 11:06:45 »
Hi
Do you have to remove the steering wheel to gain access to the bulbs behind the dashboard.
Also is replacing all the lamps of the dashboard a big job, are there any shortcuts.
Thanks. :)
RichardH
  • Ireland
Re: Dashboard Lights.
« Reply #1 on: 26 July 2009, 11:17:08 »
Here you go.  It's a very straightforward procedure.
http://www.omegaowners.com/forum/YaBB.pl?num=1192573381
REvil71
  • Wales
    • 3.2 Elite Saloon
« Reply #2 on: 26 July 2009, 11:23:10 »
Lovely. thanks.
Are the bulbs standard from say halfords or vauxhall.
« Reply #3 on: 26 July 2009, 11:42:38 »
Lovely. thanks.
Yep
I_want_an_Omega
« Reply #4 on: 29 July 2009, 17:57:03 »
I've just taken mine out for the first time - very easy thanks to the guide.
Ludvig
  • Uppsala, Sweden
« Reply #5 on: 29 July 2009, 23:28:25 »
I did this job yesterday on my 2003 Omega. It is an easy job, following the guides on the forum.
I'd only want to add a suggestion. It is a lot easier to get the dashboard out if you remove the upper cover of the top sterring rod assembly. This is easily done by following these steps:
1. Remove the two screws holding the upper and lower covers together.
2. Turn the steering wheel to the 3 O'clock and 9 O'clock positions respectively. Remove the small covers over the scews. Remove screws.
3. Remove upper cover.
4. With only the narrow cover strip being in the way of the lowers screw holding the dashboard, it should be easy to unscrew.
 8-)
