Author Topic: DTC 52  (Read 1265 times)
Paul at Home
  • Warwick
DTC 52
« on: 30 July 2009, 20:17:53 »
I have plugged a laptop into my car and got Code 52 DTC!
can anyone tell me what this means and how can I fix it. I can clar the fault code but that don't stop me from getting the Auto Gearbox fault indication :-[
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: DTC 52
« Reply #1 on: 30 July 2009, 20:27:40 »
What engine have you got?
The only reference to code 52 I can find is "check lamp voltage high". Which isn't particularly helpful...
Paul at Home
  • Warwick
Re: DTC 52
« Reply #2 on: 30 July 2009, 20:32:19 »
Hi Mine is a 2.5 V6 and I Google DTC 52 and got Reprogramme Cluster or SDM not Configured or Heater and air Con control not programmed.
the heater works so that's one down.
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: DTC 52
« Reply #3 on: 30 July 2009, 21:42:15 »
dont know what dct 52 is but on the list I have its telltale (check light ) voltage high.
try the paperclip test and see if you get any codes with it. here is a list of codes for the V6
www.omegaowners.com/forum/YaBB.pl?num=1160152415
He who brakes Looses
To old to die young
Re: DTC 52
« Reply #4 on: 30 July 2009, 22:05:57 »
if you are trying to sort a gearbox problem, you need to read gearbox ecu ;)
Re: DTC 52
« Reply #5 on: 30 July 2009, 22:23:01 »
paper clip test and pedal trick only read engine ecu remember. Will need a reader of some sort for all else.
