Author Topic: Omega W reg 2.0 auto gear box oil change?  (Read 766 times)
slavi13
« on: 01 August 2009, 15:04:36 »
Hi all.I need help.I need to change the gear box oil of my love but I don't know where is the hole for the oil,where is the deep stick,or do I need a filter for that or what oil i need or where to get all the stuff.Can some one whit more experianse halp me please.Tanks to all. :-?
« Last Edit: 01 August 2009, 15:39:42 by slavi13 »
Re: Omega W reg 2.0 auto gear box oil change?
« Reply #1 on: 01 August 2009, 16:43:32 »
You need DEX3 ATF (Auto Transmission Fluid)
No dip stick - there is a level/filler plug at top of large gearbox sump, drivers side (UK).
Remove plug (13mm), top up till fluid runs out, put plug in loosely (tight enough to stop fluid coming out)
Ensure car on level surface, start engine and move gear change back and forward through gears a few times.  Put in park.  Leave engine running, remove gearbox plug and let any excess fluid drain into container, or top up till just overflowing if no excess coming out.  When fluid stops coming out of plug hole refit 13mm plug and tighten.
Job done  :y
[edit]Just noticed you want to change fluid - to get it all out you need to remove both gearbox sumps.  Clean filter.  Refit all and refill fluid as above[/edit]
« Last Edit: 01 August 2009, 16:45:08 by dbug »
