Author Topic: Key gubbins / codes etc  (Read 1183 times)
Spearmint
  • Corby
« on: 31 July 2009, 16:03:27 »
Right then, the push buttons on the key are FUBAR'd so I thought I would take it apart to see if I could swap the chipset over to another and I found that the chipset was damaged too.
The previous owner (God only knows what the pillock was thinking!) must have had it apart before now and has used gaffa tape on the inside to hold the little switches onto the board.
So now the key won't work full stop.
Phoned Vauxhall up which I really loath doing as you may as well drop your trousers and ask them to go in dry whereby they quoted me....
£34 inc VAT for the internals.
£23 inc VAT for the Programming
He then said that as I don't have the security code there would be a further charge to acquire this code!
Honest to god what a bunch of robbing pricks!
So I don't suppose there is a cheaper way of doing this is there?
Thanks in advance.
ScottieMV6
  • Swinton, Manchester
Re: Key gubbins / codes etc
« Reply #1 on: 31 July 2009, 17:07:44 »
Martin Imber on here does some form of key repair. Not sure what he does but worth a PM to see if he can sort it for you :y
I'd rather be scared to death than bored to death!!
Spearmint
  • Corby
« Reply #2 on: 31 July 2009, 18:00:53 »
Ok, cheers for the heads-up Scottie.  :y
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« Reply #3 on: 02 August 2009, 12:00:32 »
have had similiar probs over the last couple of days. in my case the battery holder was broken away from the circuit board (on two keys ) IanD soldered them back on.both working fine now. i was quoted £70 per key.  :y
