Author Topic: Front springs 2.5td  (Read 951 times)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Front springs 2.5td
« on: 31 July 2009, 21:12:35 »
Anyone got an front spring for a tractor lying around ?
I have found a company that will make me a pair of standard height, up-rated springs but they need an original spring in order to develop the up-rated jobbies.
tombstone
Re: Front springs 2.5td
« Reply #1 on: 01 August 2009, 19:45:08 »
I have removed a pair of springs that were replaced last year on my 2.0 97 S reg if you get stuck! length be ok, but rate be slightly off! I have just fitted -40mm springs! Have you tried coilsprings.co.uk??
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #2 on: 01 August 2009, 22:34:11 »
Nice one Tombstone.
I've been dealing with Andy at Faulkner Springs.  http://www.dfaulknersprings.co.uk
He's quoted between £50 to £60 per spring but will need a sample spring and some info on weight of car etc.
The straight six BMW lump in the 2.5td is significantly heavier than the other Miggy engines and the springs are beefed up accordingly, just not enough.
I'll ask if it has to be the specific spring for the 2.5td. I suspect there may be a difference and they probably need the specific O/E jobbie.
I lowered my '94 Elite by 40mm. Darned good handling for a big old barge.  :y
Cheers
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 02 August 2009, 14:10:56 »
Picked this up from another thread, but gotta be worth a try for you .........
Fellow OOFer 'Derek_in_Penzance' can be contacted on 01736 810500 or 07774 418407.
Email: Derek@GM6Spares.fsnet.co.uk
Good luck Sir Sospan!
« Last Edit: 02 August 2009, 14:11:17 by Reliance505 »
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #4 on: 02 August 2009, 18:16:16 »
Many thanks Lord Maesteg. I'll look into that.  :y
