Author Topic: Facelift 2.2DTi turbo replacement  (Read 1402 times)
V8S
  • Dorset
« on: 29 July 2009, 19:40:12 »
Hi all,
Long time since I've been here, but that is good news in one way - no problems with the Omega! :)
Anyway, I now have a worn turbo that is whistling happily away and have been told it's not really repairable and I would need a new one. Been quoted £450 for the turbo, £100 fitting.
Any ideas of the best place to get one and what part I'm looking for?
I would also like to attempt replacement myself - how big a job is this? Any tips?
Thanks in advance, chaps. :y
V8S
  • Dorset
Re: Facelift 2.2DTi turbo replacement
« Reply #1 on: 03 August 2009, 10:14:55 »
Anyone?
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 03 August 2009, 10:48:49 »
Dont know about turbo for migs, but I know they can be tricky ones, very easily damaged if not fitted correctly.
I think it is better to pay for the fitting of this part than to attempt it yourself cause yuo can end up buying another one soon
tofer
« Reply #3 on: 03 August 2009, 10:56:28 »
I've changed a few turbos, one on an Isuzu Trooper 3.1td and a couple on 2.0litre Turbo Rovers. If the garage only wants £100 for fitting that seems very cheap, although £450 is a bit excessive for the part IMO. It's a simple enough job to do but a complete pain normally due to the huge amounts of heat involved in turbo operartion, the bolts are normally a complete pig to undo and in a fore-aft mounted engine you may have some accessibility issues.
« Reply #4 on: 03 August 2009, 11:47:43 »
Access to the turbo on a 2.2DTi seems quite good as its mounted quite high up.
« Reply #5 on: 03 August 2009, 12:17:21 »
Indeed, not a difficult job.
I have used Midland Turbos in the past for re-furb (200-300 quid) and they have been excellent.
I would be wanting to know the reasons for failure as they rarely go!
tofer
« Reply #6 on: 03 August 2009, 12:34:00 »
Turbo oil seals normally isn't it?
« Reply #7 on: 03 August 2009, 12:46:29 »
Possibly....but why?
On a recon part you can often ask for a report on the failure
« Reply #8 on: 03 August 2009, 18:18:37 »
GM's daft service schedule.....
