Author Topic: MOT failure for broken door handle?  (Read 7767 times)
yatesDELTA
« on: 05 August 2009, 01:51:31 »
Hi, front passenger door handle on my car snapped of months ago and i was going to buy one off a member here but forgot all about it, got used to opening door for SWMBO from inside so it doesn't bother me anymore since i normally drive alone.
However a neighbor said he thinks the car will fail its MOT for this, whilst its not due for a while would be nice to know so i can fix it soon if i have to
Thanks, Alex
sparkyw666.
  • aberdeen uk
  • aka mark w
Re: MOT failure for broken door handle?
« Reply #1 on: 05 August 2009, 02:16:15 »
Thanks, Alex
hi alex my friends car has no door handles has to open by key fob also only opens at driver door you can still open passengers door from inside so think you will be fine :y
« Last Edit: 05 August 2009, 02:17:23 by sparkyw666 »
v6 cam locking kit  member:y
« Reply #2 on: 05 August 2009, 05:56:09 »
Thanks, Alex
http://www.motuk.co.uk/manual_620.htm
It's a fail.  ;)
« Reply #3 on: 05 August 2009, 08:20:35 »
Thanks, Alex
It's a fail.  ;)
Without even reading the link, it's a fail. Rear doors don't have to open IIRCC but fronts must open from inside and out.
In addition I'd advise getting it sorted ASAP as it's a bit of a danger... Imagine if you had an accident and weren't able to operate the handle from inside :o :o :o
Extreme situation I know but.... Bears a little thought :y :y
yatesDELTA
« Reply #4 on: 05 August 2009, 10:39:11 »
Ah thanks, guess i had better ask someone if they have one then.
Actually strangely for the past 2 years the car didn't fail on this but the door handle didn't open the door unless you pulled it ridiculously hard so i would have thought they would have failed it for that.
« Last Edit: 05 August 2009, 10:41:02 by yatesDELTA »
tofer
« Reply #5 on: 05 August 2009, 11:17:40 »
Perhaps the tester was just heavy handed so it seemed normal to him.
