Author Topic: wishbone bushes  (Read 1303 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
wishbone bushes
« on: 05 August 2009, 13:22:16 »
on a scale of 1 - 10 how hard is the front lower wishbone bush to change there is slight play there and knocks when mobile. cheers in advance.
Matchless
  • Nottingham
    • A white van
Re: wishbone bushes
« Reply #1 on: 05 August 2009, 13:27:07 »
Cant change the bush without access to a hydraulic press....Marks DTM broke mine ;D
much easier (and similar cost) to change the wishbone, do both sides, not just one.
Difficulty depends on how rusted the bottom ball joint is.
knocking is usually from the anti-rollbar drop links.
razzo
  • Crapital
    • 97 3.0 Elite
Re: wishbone bushes
« Reply #2 on: 05 August 2009, 14:02:42 »
Bushes can be removed without a press but as new wishbones are fairly cheap i wouldn't think its worth it, unless you want to upgrade them
« Last Edit: 05 August 2009, 14:08:34 by razzo »
raywilb
    • Citroen C4 Cactus
Re: wishbone bushes
« Reply #3 on: 05 August 2009, 14:08:53 »
taking your sound advice, complete set is on its way - cheers :y :y :y
Page created in 0.068 seconds with 16 queries.
