Author Topic: windscreen washer problem  (Read 2353 times)
trainastock
  • st neots  cambridgeshire
« on: 02 August 2009, 18:56:46 »
hi all
have a problem the water that comes out to wash the windscreen it justs dribble outs about a quarter of normal pressure its a full stream that comes out but in a dribble,
any help and guidence would be great cheers  :y
Spearmint
  • Corby
Re: windscreen washer problem
« Reply #1 on: 02 August 2009, 19:00:20 »
Your pipes etc from the windscreen washer reservoir to the jets will be full of gunk.
Just had this as an MOT snag to rectify for a pass.
trainastock
« Reply #2 on: 02 August 2009, 19:02:51 »
 spearmint whats the best way to clean these ?
  • Auckland
    • Mazda MPV
« Reply #3 on: 02 August 2009, 19:50:31 »
I don't know if this is the best way but it after 6 years of poor jets this is what fixed it for me.
Tools: 0.5mm interdental brush, 100psi air compressor
1. Use interdental brush to loosen the dirt in each of the jets. Alternately brush then squirt to get the hard deposits moving. After a while you will get to the stage where there are some big bits inside the washer jets that won't come out.
2. lift bonnet and disconnect washer pipe behind hinge on passenger side.
3. close bonnet and blow compressed air into the washer jets to flush the big bits back down the pipe. If you don't do this all the rubbish you carefully cleaned out of your jets will come back up the pipe and block them again.
4. reconnect washer pipe & spend all morning redirecting the washer jets ;)
« Last Edit: 02 August 2009, 19:52:16 by andyh »
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #4 on: 02 August 2009, 21:01:10 »
You could also use a needle to clean the jets out, take the pipes off the back of the jets and use your pump to pump the rest of dirt out. and check that your bottle is clean.
He who brakes Looses
To old to die young
trainastock
« Reply #5 on: 02 August 2009, 21:43:20 »
excellent will give it a blast   :)
Spearmint
  • Corby
« Reply #6 on: 02 August 2009, 22:49:53 »
Yup, just like the guys above said. :)
« Reply #7 on: 03 August 2009, 20:19:28 »
What Andy H says, and ....... you'll probably find that the filter in the washer pump tank is full of slimey gunge too. The pump is just a push fit into a grommet in the tank, but, this grommet also incorporates a filter - it looks like a thimble - and this filter needs removing and cleaning out. Then your washer pump water will manage to hit the screen!  ;)   :y  :y  :y
trainastock
« Reply #8 on: 03 August 2009, 22:06:36 »
excellent help folks  am off on wednesday will give it a go
thanks for all your help :y :y :y
trainastock
« Reply #9 on: 05 August 2009, 18:06:45 »
all fixed  thanks for all the help   30 mins fix
cheers all  :y :y :y :y :y :y :y :y :y :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #10 on: 05 August 2009, 18:42:27 »
I had a similar problem which the old needle trick couldent handle.  So I took the washer jets off and soaked them in a small cup of Cillit Bang making sure plenty of the product went into the jets.  30 mins later a quick rinse and popped them back on and they're as good as new  :y
trainastock
« Reply #11 on: 05 August 2009, 19:48:34 »
excellent will give that a go next time  she has a wax and polish :y
